Hi everyone, I'm a beginner to the ESP-IDF world. I am developing an application in which an ESP32 module receives, through an SPI peripheral, a stream of data from an STM32 card. I need to transmit the data received through the wifi of the ESP32 module to another ESP32 module. On the SPI peripheral, about every 126 us I receive a buffer consisting of 90 words of 16 bits. Doing two calculations, I need to transmit all this data with a speed of about 23Mbps. My questions are:
1) Is it possible to use the ESP32 card for transmissions with this speed? Or do I have HW/SW limits?
2) If possible, how do you advise me to proceed, what protocol to use?
I thank in advance all those who will answer
WiFi stream
Re: WiFi stream
I am experimenting with various solutions in VS code and at the moment I am trying to transmit a string of few characters. I am using the code of 4 examples provided with esp-idf and below are the codes for the client and for the server and what the two terminals show. The problem is that the client transmits the message but the server receives nothing, it seems as if it is waiting to receive something. What's up? Some idea? A little help? A suggestion? Thanks in advance
Client terminal
Server terminal
Client Code
Server Code
Client terminal
I (1563) esp_netif_handlers: sta ip: 10.10.1.2, mask: 255.255.255.0, gw: 10.10.1.0
I (1563) Client: got ip:10.10.1.2
I (1563) Client: connected to ap SSID:ESP32_1 password:
I (1573) Client: Socket created, sending to 10.10.10.1:55555
I (3573) Client: Message sent
I (6444) Server: station 0a:0a:0a:0a:0a:01 join, AID=1
I (6444) Server: Socket created
I (6454) Server: Socket bound, port 55555
I (6464) Server: Waiting for data
I (6464) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 10.10.1.2
#include <string.h>
#include <sys/param.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include <lwip/netdb.h>
#define HOST_IP_ADDR CONFIG_EXAMPLE_IPV4_ADDR
#define PORT CONFIG_EXAMPLE_PORT
#define EXAMPLE_ESP_WIFI_SSID "ESP32_1"
#define EXAMPLE_ESP_WIFI_PASS ""
#define EXAMPLE_ESP_MAXIMUM_RETRY 10
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT BIT1
static EventGroupHandle_t s_wifi_event_group;
static const char *TAG = "Client";
static const char *payload = "Message from client ESP32\r";
static const uint8_t mac[6] = {0xa, 0xa, 0xa, 0xa, 0xa, 0x1};
static int s_retry_num = 0;
static void event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
esp_wifi_connect();
} else if (event_base == WIFI_EVENT && (event_id == WIFI_EVENT_STA_DISCONNECTED || event_id == WIFI_EVENT_AP_STADISCONNECTED)) {
if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
esp_wifi_connect();
s_retry_num++;
ESP_LOGI(TAG, "retry to connect to the AP");
xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
ESP_LOGI(TAG,"connect to the AP fail");
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
s_retry_num = 0;
xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
s_wifi_event_group = xEventGroupCreate();
esp_netif_create_default_wifi_sta();
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
&event_handler,
NULL,
&instance_got_ip));
esp_wifi_set_mac(ESP_IF_WIFI_STA, mac);
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.password = EXAMPLE_ESP_WIFI_PASS,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
ESP_ERROR_CHECK(esp_wifi_start() );
ESP_LOGI(TAG, "wifi_init_sta finished.");
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
pdFALSE,
pdFALSE,
portMAX_DELAY);
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
} else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
ESP_LOGE(TAG, "UNEXPECTED EVENT");
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
vEventGroupDelete(s_wifi_event_group);
static void udp_client_task(void *pvParameters)
char rx_buffer[128];
char host_ip[] = HOST_IP_ADDR;
int addr_family = 0;
int ip_protocol = 0;
while (1) {
struct sockaddr_in dest_addr;
dest_addr.sin_addr.s_addr = inet_addr(HOST_IP_ADDR);
dest_addr.sin_family = AF_INET;
dest_addr.sin_port = htons(PORT);
addr_family = AF_INET;
ip_protocol = IPPROTO_IP;
int sock = socket(addr_family, SOCK_DGRAM, ip_protocol);
if (sock < 0) {
ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
ESP_LOGI(TAG, "Socket created, sending to %s:%d", HOST_IP_ADDR, PORT);
while (1) {
int err = sendto(sock, payload, strlen(payload), 0, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
if (err < 0) {
ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno);
ESP_LOGI(TAG, "Message sent");
struct sockaddr_storage source_addr; // Large enough for both IPv4 or IPv6
socklen_t socklen = sizeof(source_addr);
int len = recvfrom(sock, rx_buffer, sizeof(rx_buffer) - 1, 0, (struct sockaddr *)&source_addr, &socklen);
// Error occurred during receiving
if (len < 0) {
ESP_LOGE(TAG, "recvfrom failed: errno %d", errno);
// Data received
else {
rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string
ESP_LOGI(TAG, "Received %d bytes from %s:", len, host_ip);
ESP_LOGI(TAG, "%s", rx_buffer);
if (strncmp(rx_buffer, "OK: ", 4) == 0) {
ESP_LOGI(TAG, "Received expected message, reconnecting");
vTaskDelay(2000 / portTICK_PERIOD_MS);
if (sock != -1) {
ESP_LOGE(TAG, "Shutting down socket and restarting...");
shutdown(sock, 0);
close(sock);
vTaskDelete(NULL);
void app_main(void)
ESP_ERROR_CHECK(nvs_flash_init());
wifi_init_sta();
xTaskCreate(udp_client_task, "udp_client", 4096, NULL, 5, NULL);
#include <string.h>
#define EXAMPLE_ESP_WIFI_CHANNEL 13
#define EXAMPLE_MAX_STA_CONN 1
static const char *TAG = "Server";
static const uint8_t mac[6] = {0xa, 0xa, 0xa, 0xa, 0xa, 0x0};
bool flagSta = false;
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
if (event_id == WIFI_EVENT_AP_STACONNECTED) {
wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" join, AID=%d", MAC2STR(event->mac), event->aid);
flagSta = true;
} else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) {
wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" leave, AID=%d", MAC2STR(event->mac), event->aid);
flagSta = false;
static void udp_server_task(void *pvParameters)
char addr_str[128];
int addr_family = (int)pvParameters;
struct sockaddr_in6 dest_addr;
while (1) {
struct sockaddr_in *dest_addr_ip4 = (struct sockaddr_in *)&dest_addr;
dest_addr_ip4->sin_addr.s_addr = htonl(INADDR_ANY);
dest_addr_ip4->sin_family = AF_INET;
dest_addr_ip4->sin_port = htons(PORT);
if (sock < 0) {
ESP_LOGI(TAG, "Socket created");
int err = bind(sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
if (err < 0) {
ESP_LOGE(TAG, "Socket unable to bind: errno %d", errno);
ESP_LOGI(TAG, "Socket bound, port %d", PORT);
while (flagSta) {
ESP_LOGI(TAG, "Waiting for data");
ESP_LOGI(TAG, "Ricevuti %d bytes\n", len);
if (len < 0) {
// Data received
else {
// Get the sender's ip address as string
if (source_addr.ss_family == PF_INET) {
inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr, addr_str, sizeof(addr_str) - 1);
} else if (source_addr.ss_family == PF_INET6) {
inet6_ntoa_r(((struct sockaddr_in6 *)&source_addr)->sin6_addr, addr_str, sizeof(addr_str) - 1);
rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string...
ESP_LOGI(TAG, "Received %d bytes from %s:", len, addr_str);
int err = sendto(sock, rx_buffer, len, 0, (struct sockaddr *)&source_addr, sizeof(source_addr));
if (err < 0) {
if (sock != -1) {
shutdown(sock, 0);
close(sock);
vTaskDelete(NULL);
void wifi_init_softap(void)
esp_netif_t *ap_netif = esp_netif_create_default_wifi_ap();
assert(ap_netif);
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
NULL));
.ap = {
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.channel = EXAMPLE_ESP_WIFI_CHANNEL,
.max_connection = EXAMPLE_MAX_STA_CONN,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_netif_dhcps_stop(ap_netif));
esp_netif_ip_info_t ip_info;
IP4_ADDR(&ip_info.ip, 10, 10, 1, 1);
IP4_ADDR(&ip_info.gw, 10, 10, 1, 0);
IP4_ADDR(&ip_info.netmask, 255, 255, 255, 0);
esp_wifi_set_mac(ESP_IF_WIFI_AP, mac);
ESP_ERROR_CHECK(esp_netif_set_ip_info(ap_netif, &ip_info));
ESP_ERROR_CHECK(esp_netif_dhcps_start(ap_netif));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s channel:%d",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS, EXAMPLE_ESP_WIFI_CHANNEL);
void app_main(void)
wifi_init_softap();
xTaskCreate(udp_server_task, "udp_server", 4096, (void*)AF_INET, 5, NULL);
Re: WiFi stream
Is it possible that no one wants/can give me help, a suggestion, constructive criticism, something? In any case I think it's a bug, it's really weird that the recvfrom command gets stuck waiting when the client keeps sending messages. So, I ask the admins to move this thread to the bug forum. A thousand thanks
Re: WiFi stream
Well, let's start at the beginning. Are you sure the sender transmits it? Can you set up a program on a PC to send/receive messages and see what that does?
Re: WiFi stream
Thanks for the reply, I will gladly do it, maybe it is the transmitter that is not transmitting.
Re: WiFi stream
I'm sorry for the late reply. As soon as I could I verified that the client is actually transmitting, to do this I used wireshark. I used my pc as a wifi server and the ESP32 module as a client, the program used by the latter is the same as shown in some posts above. Wireshark captured the packets transmitted by the client as shown in the image below.
This means that in the project with the two ESP32 modules the client transmits while the server waits to receive. The question remains, what am I wrong? Is it a bug? Any suggestions? Please help!
Users browsing this forum: Baidu [Spider] and 218 guests
