I'm looking for information on programming the DMA controller on the ESP32 (beyond what is in the Tech. Ref.). Specifically I want to understand how to trigger a DMA burst using a GPIO (not mediated using an interrupt on the CPU).
The scenario is this: I have an SPI connected ADC. The ADC provides a pin that signals a conversion is ready. Every time that happens I want the SPI to read from the ADC and DMA to transfer the read data into a circular buffer. It seems like that it is possible to make a circular buffer using a circular dma config linked list with a single entry. But where do I configure a trigger? Is this even possible with ESP32?
Regards,
Felix
How to trigger DMA from external input
Re: How to trigger DMA from external input
You can't on current ESP chips, you'll need to have an interrupt on that GPIO that manually triggers the SPI transfer.
Thanks for that. It is as I suspected. Now I have a problem.ESP_Sprite wrote: ↑Fri May 13, 2022 1:40 amYou can't on current ESP chips, you'll need to have an interrupt on that GPIO that manually triggers the SPI transfer.
I need to read 8bytes from ADC over SPI when an interrupt fires every ~60uS. This is too fast to get a freertos task to do the read with a task notify fired from the interrupt. But I can not do SPI read from the interrupt itself. How would this be done on ESP32?
I could poll the ADC on the SPI until I get the valid data. But this seems wasteful and I have a lot to fit into this firmware...
Is it possible to start a DMA SPI transaction from a gpio interrupt and then handle the transaction finished interrupt to copy the data to a buffer?
Looking at the code in spi_device_queue_trans() It looks like I could duplicate that and use xQueueSendFromISR to make it ISR compatible. Any IDF developers care to comment?
I tried that solution, queue spi transaction from isr. It knocks quite a bit of overhead off but there is still around 20uS of task switching and queue overhead.
Users browsing this forum: No registered users and 123 guests
