WiFi debug log in IDF 4.4.x ?
RalphD
Postby RalphD » Sat May 14, 2022 9:42 pm
How to enable WiFi debug log ? it does not appear in menuconfig using Eclipse IDE
mbratch
Re: WiFi debug log in IDF 4.4.x ?
Postby mbratch » Tue May 17, 2022 1:18 am
Wifi debug is included with other debug information in 4.4.x I believe. It's not a separate option as of later ESP-IDF versions. You'll just need to increase log level to get more of it. You can also still set:
Component config --> Supplicant --> [*] Print debug messages from WPA Supplicant
RalphD
Postby RalphD » Tue May 17, 2022 6:48 am
In earlier versions has been a dedicated debug option under WiFi. I just want to know if this debug level is now included in the general logging. It seems like and thanks for pointing me to the supplicant menu.
mbratch
Postby mbratch » Tue May 17, 2022 12:34 pm
Yes, earlier versions of ESP-IDF had separate wifi logging enable in the config.
I don't think wifi logging has been reduced. You just need to enable logging level as desired, and possibly some of the WPA supplicant logging if you're trying to diagnose wifi issue. Have you tried it and determined that there's insufficient wifi logging?
RalphD
Postby RalphD » Tue May 17, 2022 1:35 pm
yes, and it reports a beacon time out and reconnects after 10+ trials. However that is very deep in the WiFi stack and FCC related so if there is no log on this deep level provided, no chance to nail that down as a user. Remember, FCC approval requires to use the same binary and only this binary on this device passes approval. I don't know how Espressif handles this here and anyone has access to the source. Haven't gone into it yet.
mbratch
Postby mbratch » Tue May 17, 2022 7:03 pm
Indeed. I don't know if the maximum verbosity setting for logging provides what you need. That said, it's unclear then whether the prior wifi-specific logging would have, either.
Users browsing this forum: pacucha42 and 112 guests
