Hi
My ESP32 DEVKITV1 is not seen by Arduino IDE (it tells none on COM5).
With Arduino Uno card I am able to load software.
My Os is Window 10.
ESP32 Port
Re: ESP32 Port
Did you select your ESP32 as the platform in the IDE before attempting to connect? Or are you saying your particular platform doesn't show up in the list of choices?
Re: ESP32 Port
Hi
I select the correct board (I hope: DOIT ESP32 DEVKIT V1) on tools.
Re: ESP32 Port
With your ESP32 plugged in via USB, check your device manager in Windows and verify the COM port number there.
Re: ESP32 Port
Thanks mbratch
Whe I attach Arduino 1 appears COM5; attaching ESP32 appears
Now I see COM6
Very thanks
So I downloaded the CP2102 driver and installed.Other devices
CP2102 USB to UART Bridge Controller
Now I see COM6
Very thanks
Users browsing this forum: Bing [Bot] and 112 guests
