What it the secret to compiling the examples in:
esp-idf/components/tinyusb/tinyusb/examples/device/hid_composite_freertos
and
esp-idf/components/tinyusb/tinyusb/examples/device/cdc_msc_freertos ?
Using 'make BOARD=espressif_addax_1 all' in these directories results in: #error "This port requires __NVIC_PRIO_BITS to be defined"
If I clone the original TinyUSB repo (https://github.com/hathach/tinyusb) the examples compile without an error.
What am I missing?
Error when compiling the TinyUSB examples for ESP32-S3
Re: Error when compiling the TinyUSB examples for ESP32-S3
Have you included a "FreeRTOSConfig.h" in your project? Delete it and try again.
from https://docs.espressif.com/projects/esp ... ertos.html:
I'm also experimenting with this TinyUSB code, and even after fixing this bug, I'm encountering other issues, so YMMV.Vanilla FreeRTOS allows ports and applications to configure the kernel by adding various #define config... macros to FreeRTOSConfig.h. Through these macros, the kernel’s scheduling behavior and various kernel features can be enabled or disabled. However, in ESP-IDF FreeRTOS, the ``FreeRTOSConfig.h`` file is considered a private and must not be modified by users. Any FreeRTOS configuration that is exposed to the user will be done so via menuconfig.
Users browsing this forum: endi83 and 164 guests
