i want to connect 2 ESPs one as AP and second as station. Then send and recivee data among them.
I thought of adding UDP server example in Wifi Soft AP , UDP client already have function to make ESP act as station
but the sockets are being created but their is no connection between them even though IP, name of wifi's are same .
Can anyone help or direct me to some document to do so
Board: ESP32
using : VS code for ESP IDF
thank you
How to send data over Wifi in soft Ap and station mode in ESp IDF
Re: How to send data over Wifi in soft Ap and station mode in ESp IDF
Hi KamalChopra
For SoftAP + UDP server, i think you can follow this two examples https://github.com/espressif/esp-idf/bl ... ple_main.c and https://github.com/espressif/esp-idf/tr ... udp_server. udp_server is lanuched with STA mode and you can remove it and add SoftAP mode.
For STA + UDP client, we have example https://github.com/espressif/esp-idf/tr ... udp_client.
ESP_YJM wrote: ↑Thu May 26, 2022 10:10 amHi KamalChopra
I tried what you said but the code is getting stuck i don't know why can you please suggent what needs to be fixed
// Wifi station + UDP client side :
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:6896
ho 0 tail 12 room 4
load:0x40078000,len:13076
load:0x40080400,len:3900
0x40080400: _init at ??:?
entry 0x40080688
I (31) boot: ESP-IDF v4.1.3-dirty 2nd stage bootloader
I (31) boot: compile time 12:58:09
I (31) boot: chip revision: 3
I (34) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (42) boot.esp32: SPI Speed : 40MHz
I (46) boot.esp32: SPI Mode : DIO
I (51) boot.esp32: SPI Flash Size : 4MB
I (55) boot: Enabling RNG early entropy source...
I (61) boot: Partition Table:
I (64) boot: ## Label Usage Type ST Offset Length
I (72) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (79) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (86) boot: 2 factory factory app 00 00 00010000 00100000
I (94) boot: End of partition table
I (98) boot_comm: chip revision: 3, min. application chip revision: 0
I (105) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x15ec0 ( 89792) map
I (148) esp_image: segment 1: paddr=0x00025ee8 vaddr=0x3ffb0000 size=0x03180 ( 12672) load
I (154) esp_image: segment 2: paddr=0x00029070 vaddr=0x40080000 size=0x00404 ( 1028) load
0x40080000: _WindowOverflow4 at /media/swapnil/Bibox/ESP_IDF/esp-idf/components/freertos/xtensa_vectors.S:1778
I (156) esp_image: segment 3: paddr=0x0002947c vaddr=0x40080404 size=0x06b9c ( 27548) load
I (176) esp_image: segment 4: paddr=0x00030020 vaddr=0x400d0020 size=0x6e1d8 (451032) map
0x400d0020: _stext at ??:?
I (348) esp_image: segment 5: paddr=0x0009e200 vaddr=0x40086fa0 size=0x0e1c4 ( 57796) load
0x40086fa0: spiflash_start at /media/swapnil/Bibox/ESP_IDF/esp-idf/components/spi_flash/esp_flash_api.c:85
I (385) boot: Loaded app from partition at offset 0x10000
I (385) boot: Disabling RNG early entropy source...
I (386) cpu_start: Pro cpu up.
I (389) cpu_start: Application information:
I (394) cpu_start: Project name: udp_client
I (399) cpu_start: App version: 1
I (404) cpu_start: Compile time: May 21 2022 12:57:59
I (410) cpu_start: ELF file SHA256: f7c6e5a6d69d77d1...
I (416) cpu_start: ESP-IDF: v4.1.3-dirty
I (421) cpu_start: Starting app cpu, entry point is 0x400812f4
0x400812f4: call_start_cpu1 at /media/swapnil/Bibox/ESP_IDF/esp-idf/components/esp32/cpu_start.c:276
I (0) cpu_start: App cpu up.
I (432) heap_init: Initializing. RAM available for dynamic allocation:
I (439) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (445) heap_init: At 3FFB80E8 len 00027F18 (159 KiB): DRAM
I (451) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (457) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (464) heap_init: At 40095164 len 0000AE9C (43 KiB): IRAM
I (470) cpu_start: Pro cpu start user code
I (488) spi_flash: detected chip: generic
I (489) spi_flash: flash io: dio
I (489) cpu_start: Starting scheduler on PRO CPU.
I (580) wifi:wifi driver task: 3ffc0680, prio:23, stack:6656, core=0
I (580) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (610) wifi:wifi firmware version: d333e55
I (610) wifi:config NVS flash: enabled
I (610) wifi:config nano formating: disabled
I (610) wifi:Init data frame dynamic rx buffer num: 32
I (620) wifi:Init management frame dynamic rx buffer num: 32
I (620) wifi:Init management short buffer num: 32
I (630) wifi:Init dynamic tx buffer num: 32
I (630) wifi:Init static rx buffer size: 1600
I (630) wifi:Init static rx buffer num: 10
I (640) wifi:Init dynamic rx buffer num: 32
I (640) wifi_init: rx ba win: 6
I (650) wifi_init: tcpip mbox: 32
I (650) wifi_init: udp mbox: 6
I (650) wifi_init: tcp mbox: 6
I (660) wifi_init: tcp tx win: 5744
I (660) wifi_init: tcp rx win: 5744
I (660) wifi_init: tcp mss: 1440
I (670) wifi_init: WiFi IRAM OP enabled
I (670) wifi_init: WiFi RX IRAM OP enabled
I (680) example_connect: Connecting to myssid...
I (680) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (820) wifi:mode : sta (7c:9e:bd:d8:4e:b4)
I (820) example_connect: Waiting for IP
I (2870) wifi:new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
I (3630) wifi:state: init -> auth (b0)
I (3640) wifi:state: auth -> assoc (0)
I (3660) wifi:state: assoc -> run (10)
I (3670) wifi:connected with myssid, aid = 1, channel 1, 40U, bssid = 7c:9e:bd:d8:53:f1
I (3670) wifi:security: WPA2-PSK, phy: bgn, rssi: -30
I (3670) wifi:pm start, type: 1
I (3730) wifi:AP's beacon interval = 102400 us, DTIM period = 2
I (4560) esp_netif_handlers: sta ip: 192.168.43.43, mask: 255.255.255.0, gw: 192.168.43.42
I (4560) example_connect: Got IP event!
I (5560) example_connect: Got IPv6 event!
I (5560) example_connect: Connected to myssid
I (5560) example_connect: IPv4 address: 192.168.43.43
I (5560) example_connect: IPv6 address: fe80:0000:0000:0000:7e9e:bdff:fed8:4eb4
I (5570) example: Socket created, sending to 192.168.0.165:3333
I (5580) example: Message sent
// Wifi Ap mode + UDP server side
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x40080688
I (31) boot: compile time 14:39:53
I (105) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x15bb0 ( 89008) map
I (148) esp_image: segment 1: paddr=0x00025bd8 vaddr=0x3ffb0000 size=0x03180 ( 12672) load
I (154) esp_image: segment 2: paddr=0x00028d60 vaddr=0x40080000 size=0x00404 ( 1028) load
I (155) esp_image: segment 3: paddr=0x0002916c vaddr=0x40080404 size=0x06eac ( 28332) load
I (176) esp_image: segment 4: paddr=0x00030020 vaddr=0x400d0020 size=0x6e88c (452748) map
I (349) esp_image: segment 5: paddr=0x0009e8b4 vaddr=0x400872b0 size=0x0deb4 ( 57012) load
0x400872b0: doBacktrace at /media/swapnil/Bibox/ESP_IDF/esp-idf/components/esp32/panic.c:497
I (386) boot: Loaded app from partition at offset 0x10000
I (386) boot: Disabling RNG early entropy source...
I (390) cpu_start: Application information:
I (395) cpu_start: Project name: udp_server
I (400) cpu_start: App version: 1
I (404) cpu_start: Compile time: May 27 2022 14:39:42
I (410) cpu_start: ELF file SHA256: 516fc0c9329ee0d2...
I (422) cpu_start: Starting app cpu, entry point is 0x400812f4
I (445) heap_init: At 3FFB80C0 len 00027F40 (159 KiB): DRAM
I (458) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (489) spi_flash: detected chip: generic
I (585) wifi:wifi driver task: 3ffc08f0, prio:23, stack:6656, core=0
I (585) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (615) wifi:wifi firmware version: d333e55
I (615) wifi:config NVS flash: enabled
I (615) wifi:config nano formating: disabled
I (615) wifi:Init data frame dynamic rx buffer num: 32
I (615) wifi:Init management frame dynamic rx buffer num: 32
I (625) wifi:Init management short buffer num: 32
I (625) wifi:Init dynamic tx buffer num: 32
I (635) wifi:Init static rx buffer size: 1600
I (635) wifi:Init static rx buffer num: 10
I (645) wifi:Init dynamic rx buffer num: 32
I (645) wifi_init: rx ba win: 6
I (645) wifi_init: tcpip mbox: 32
I (655) wifi_init: udp mbox: 6
I (655) wifi_init: tcp mbox: 6
I (665) wifi_init: tcp tx win: 5744
I (665) wifi_init: tcp rx win: 5744
I (665) wifi_init: tcp mss: 1440
I (675) wifi_init: WiFi IRAM OP enabled
I (675) wifi_init: WiFi RX IRAM OP enabled
I (685) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (785) wifi:mode : softAP (7c:9e:bd:d8:53:f1)
I (795) wifi:Total power save buffer number: 16
I (795) wifi:Init max length of beacon: 752/752
I (795) wifi softAP WITH udp: wifi_init_softap finished. SSID:myssid password:mypassword channel:1
I (805) wifi softAP WITH udp: Socket created
I (815) wifi softAP WITH udp: Socket bound, port 3333
I (815) wifi softAP WITH udp: Waiting for data
I (2885) wifi:new:<1,1>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (2885) wifi:station: 7c:9e:bd:d8:4e:b4 join, AID=1, bgn, 40U
I (2905) wifi softAP WITH udp: station 7c:9e:bd:d8:4e:b4 join, AID=1
I (2925) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.43.43
OnUDP client side : after socket are formed the UDP sents a packet and waits to receive a packet but here after sending the packet but gets stuck on receive function that is where it has to receive the packet from the UDP server
int len = recvfrom(sock, rx_buffer, sizeof(rx_buffer) - 1, 0, (struct sockaddr *)&source_addr, &socklen);
On UDP server side : after socket is formed the UDP first hast to receive the packet form the cient but that's not happing it is getting stuck at :
Is their a fault in IP address or something else; if yes from where to change it
thanks,
Do the IP 192.168.0.165 is your UDP server address, alsp your SotAP address. I saw your UDP client send data to this IP address. Besides, those example is only an example for user to test. You can change it when you know the socket programming.
Hi, YJM.
I have try the UDP server with soft AP following your suggesting. And the client programe is modified to send message to "255.255.255.255". The udp server succeed to resiceve the message from udp client.
So my question is : what is the IP of SoftAP for eps32. "192.168.0.1" is wrong. Need I set it myself, or there is a default one? Thanks!
It has the default softap ip 192.168.4.1.
Thank you, YJM.
Well, I tried "192.168.0.1" again sereral day ago, but it succeed, and I just don't know the reason. Maybe the UDP sever is binding for any IP, as the setting code.
dest_addr_ip4->sin_addr.s_addr = htonl(INADDR_ANY);
Can you clarify this a bit? Which IPs and names are the same? You don't mean of your two ESPs, do you?...but their is no connection between them even though IP, name of wifi's are same .
Users browsing this forum: No registered users and 283 guests
