Access to second USB slave configuration as USB host (ESP32-S3)
marbalon
Postby marbalon » Thu Jun 23, 2022 1:02 pm
I'm developing communication with a slave USB device (POS printer). Everything is fine when I have a device with only one configuration so I can get the configuration descriptor, then get the endpoint and send data to this endpoint - that is working. The problem is that some of these slave devices/printers have two configuration descriptors, and ESP32 host only sees the first one, but I have to get access to the second one and write data to an endpoint from the second configuration. Here is data from USB Device Tree view.
How can I get access to endpoints from the second configuration?
 =========================== USB Port3 ===========================
Connection Status        : 0x01 (Device is connected)
Port Chain               : 1-3
Properties               : 0x01
 IsUserConnectable       : yes
 PortIsDebugCapable      : no
 PortHasMultiCompanions  : no
 PortConnectorIsTypeC    : no
ConnectionIndex          : 0x03 (Port 3)
CompanionIndex           : 0
 CompanionHubSymLnk      : USB#ROOT_HUB30#4&38d51b6a&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
 CompanionPortNumber     : 0x13 (Port 19)
 -> CompanionPortChain   : 1-19
      ========================== Summary =========================
Vendor ID                : 0x20D1 (Dascom Europe GmbH)
Product ID               : 0x7007
USB Version              : 2.00
Port maximum Speed       : High-Speed (Companion Port 1-19 supports SuperSpeed)
Device maximum Speed     : High-Speed
Device Connection Speed  : High-Speed
Self powered             : no
Demanded Current         : 0 mA
Used Endpoints           : 3
      ======================== USB Device ========================
        +++++++++++++++++ Device Information ++++++++++++++++++
Device Description       : Uniwersalna drukarka USB
Device Path 1            : \\?\USB#VID_20D1&PID_7007#TP900021190243#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Device Path 2            : \\?\USB#VID_20D1&PID_7007#TP900021190243#{28d78fad-5a12-11d1-ae5b-0000f803a8c2} (GUID_DEVINTERFACE_USBPRINT)
Device Path 3            : \\?\USB#VID_20D1&PID_7007#TP900021190243#{a6782bce-4376-4de2-8096-70aa9e8fed19}
Kernel Name              : \Device\USBPDO-4
Device ID                : USB\VID_20D1&PID_7007\TP900021190243
Hardware IDs             : USB\VID_20D1&PID_7007&REV_0300 USB\VID_20D1&PID_7007
Driver KeyName           : {36fc9e60-c465-11cf-8056-444553540000}\0010 (GUID_DEVCLASS_USB)
Driver                   : \SystemRoot\System32\drivers\usbprint.sys (Version: 10.0.19041.1503  Date: 2022-02-10)
Driver Inf               : C:\WINDOWS\inf\usbprint.inf
Legacy BusType           : PNPBus
Class                    : USB
Class GUID               : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service                  : usbprint
Enumerator               : USB
Location Info            : Port_#0003.Hub_#0001
Location IDs             : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(3), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS03)
Container ID             : {8e740817-c4c7-58e9-96cb-14565946798e}
Manufacturer Info        : Microsoft
Capabilities             : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status                   : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code             : 0
Address                  : 3
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend   : 0
SelectiveSuspendEnabled  : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState       : 0
WakeFromSleepState       : 0
Power State              : D0 (supported: D0, D3, wake from D0)
 Child Device 1          : TP90
  Device ID              : USBPRINT\OXHOOTP90\8&1DCEC2F3&0&USB001
  Class                  : Printer
  Driver KeyName         : {4d36e979-e325-11ce-bfc1-08002be10318}\0002 (GUID_DEVCLASS_PRINTER)
   Child Device 1        : TP90 (Lokalna kolejka wydruku)
    Device ID            : SWD\PRINTENUM\{A3A131AE-5950-436E-8FC7-3BB2D014BADE}
    Class                : PrintQueue
    Driver KeyName       : {1ed2bbf9-11f0-4084-b21f-ad83a8e6dcdc}\0010 (GUID_DEVCLASS_PRINTQUEUE)
        +++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\20D170070300
 osvc                    : REG_BINARY 00 00
        ---------------- Connection Information ---------------
Connection Index         : 0x03 (Port 3)
Connection Status        : 0x01 (DeviceConnected)
Current Config Value     : 0x01 (Configuration 1)
Device Address           : 0x0C (12)
Is Hub                   : 0x00 (no)
Device Bus Speed         : 0x02 (High-Speed)
Number Of Open Pipes     : 0x02 (2 pipes to data endpoints)
Pipe[0]                  : EndpointID=1  Direction=IN   ScheduleOffset=0  Type=Bulk  wMaxPacketSize=512  bInterval=0
Pipe[1]                  : EndpointID=2  Direction=OUT  ScheduleOffset=0  Type=Bulk  wMaxPacketSize=512  bInterval=0
Data (HexDump)           : 03 00 00 00 12 01 00 02 02 00 00 40 D1 20 07 70   ...........@. .p
                           00 03 01 02 03 01 01 02 00 0C 00 02 00 00 00 01   ................
                           00 00 00 07 05 81 02 00 02 00 00 00 00 00 07 05   ................
                           02 02 00 02 00 00 00 00 00                        .........
        --------------- Connection Information V2 -------------
Connection Index         : 0x03 (3)
Length                   : 0x10 (16 bytes)
SupportedUsbProtocols    : 0x03
 Usb110                  : 1 (yes, port supports USB 1.1)
 Usb200                  : 1 (yes, port supports USB 2.0)
 Usb300                  : 0 (no, port not supports USB 3.0) -> but Companion Port 1-19 does
 ReservedMBZ             : 0x00
Flags                    : 0x00
 DevIsOpAtSsOrHigher     : 0 (Device is not operating at SuperSpeed or higher)
 DevIsSsCapOrHigher      : 0 (Device is not SuperSpeed capable or higher)
 DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
 DevIsSsPlusCapOrHigher  : 0 (Device is not SuperSpeedPlus capable or higher)
 ReservedMBZ             : 0x00
Data (HexDump)           : 03 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00   ................
    ---------------------- Device Descriptor ----------------------
bLength                  : 0x12 (18 bytes)
bDescriptorType          : 0x01 (Device Descriptor)
bcdUSB                   : 0x200 (USB Version 2.00)
bDeviceClass             : 0x02 (Communications and CDC Control)
bDeviceSubClass          : 0x00
bDeviceProtocol          : 0x00 (No class specific protocol required)
bMaxPacketSize0          : 0x40 (64 bytes)
idVendor                 : 0x20D1 (Dascom Europe GmbH)
idProduct                : 0x7007
bcdDevice                : 0x0300
iManufacturer            : 0x01 (String Descriptor 1)
 Language 0x0409         : "OXHOO"
iProduct                 : 0x02 (String Descriptor 2)
 Language 0x0409         : "TP90"
iSerialNumber            : 0x03 (String Descriptor 3)
 Language 0x0409         : "TP900021190243"
bNumConfigurations       : 0x01 (1 Configuration)
Data (HexDump)           : 12 01 00 02 02 00 00 40 D1 20 07 70 00 03 01 02   .......@. .p....
                           03 01                                             ..
    ------------------ Configuration Descriptor -------------------
bLength                  : 0x09 (9 bytes)
bDescriptorType          : 0x02 (Configuration Descriptor)
wTotalLength             : 0x0020 (32 bytes)
bNumInterfaces           : 0x01 (1 Interface)
bConfigurationValue      : 0x01 (Configuration 1)
iConfiguration           : 0x00 (No String Descriptor)
bmAttributes             : 0x80
 D7: Reserved, set 1     : 0x01
 D6: Self Powered        : 0x00 (no)
 D5: Remote Wakeup       : 0x00 (no)
 D4..0: Reserved, set 0  : 0x00
MaxPower                 : 0x00 (0 mA)
Data (HexDump)           : 09 02 20 00 01 01 00 80 00 09 04 00 00 02 07 01   .. .............
                           02 00 07 05 81 02 00 02 00 07 05 02 02 00 02 00   ................
        ---------------- Interface Descriptor -----------------
bDescriptorType          : 0x04 (Interface Descriptor)
bInterfaceNumber         : 0x00 (Interface 0)
bAlternateSetting        : 0x00
bNumEndpoints            : 0x02 (2 Endpoints)
bInterfaceClass          : 0x07 (Printer)
bInterfaceSubClass       : 0x01
bInterfaceProtocol       : 0x02
iInterface               : 0x00 (No String Descriptor)
Data (HexDump)           : 09 04 00 00 02 07 01 02 00                        .........
        ----------------- Endpoint Descriptor -----------------
bLength                  : 0x07 (7 bytes)
bDescriptorType          : 0x05 (Endpoint Descriptor)
bEndpointAddress         : 0x81 (Direction=IN EndpointID=1)
bmAttributes             : 0x02 (TransferType=Bulk)
wMaxPacketSize           : 0x0200 (max 512 bytes)
bInterval                : 0x00 (never NAKs)
Data (HexDump)           : 07 05 81 02 00 02 00                              .......
bEndpointAddress         : 0x02 (Direction=OUT EndpointID=2)
Data (HexDump)           : 07 05 02 02 00 02 00                              .......
    --------- Device Qualifier Descriptor (for Full-Speed) --------
bLength                  : 0x0A (10 bytes)
bDescriptorType          : 0x06 (Device_qualifier Descriptor)
bDeviceClass             : 0x00 (defined by the interface descriptors)
bMaxPacketSize0          : 0x40 (64 Bytes)
bNumConfigurations       : 0x01 (1 other-speed configuration)
bReserved                : 0x00
Data (HexDump)           : 0A 06 00 02 00 00 00 40 01 00                     .......@..
bmAttributes             : 0x80
Data (HexDump)           : 09 02 20 00 01 01 00 80 00 09 04 00 00 02 FF 00   .. .............
                           00 00 07 05 81 02 40 00 00 07 05 02 02 40 00 00   ......@......@..
bInterfaceClass          : 0xFF (Vendor Specific)
bInterfaceSubClass       : 0x00
bInterfaceProtocol       : 0x00
Data (HexDump)           : 09 04 00 00 02 FF 00 00 00                        .........
wMaxPacketSize           : 0x0040 (64 bytes)
bInterval                : 0x00 (ignored)
Data (HexDump)           : 07 05 81 02 40 00 00                              ....@..
Data (HexDump)           : 07 05 02 02 40 00 00                              ....@..
      -------------------- String Descriptors -------------------
             ------ String Descriptor 0 ------
bLength                  : 0x04 (4 bytes)
bDescriptorType          : 0x03 (String Descriptor)
Language ID[0]           : 0x0409 (English - United States)
Data (HexDump)           : 04 03 09 04                                       ....
             ------ String Descriptor 1 ------
bLength                  : 0x0C (12 bytes)
Data (HexDump)           : 0C 03 4F 00 58 00 48 00 4F 00 4F 00               ..O.X.H.O.O.
             ------ String Descriptor 2 ------
Data (HexDump)           : 0A 03 54 00 50 00 39 00 30 00                     ..T.P.9.0.
             ------ String Descriptor 3 ------
bLength                  : 0x1E (30 bytes)
Data (HexDump)           : 1E 03 54 00 50 00 39 00 30 00 30 00 30 00 32 00   ..T.P.9.0.0.0.2.
                           31 00 31 00 39 00 30 00 32 00 34 00 33 00         1.1.9.0.2.4.3.
Users browsing this forum: Baidu [Spider], selec1 and 158 guests
