ESPNow - receiving wrong data
Rocket2022
Postby Rocket2022 » Sat Jun 25, 2022 6:38 am
I've created some code to send and receive simple data over ESPNow.
The problem is that I've always receive 36 instead of 1 in the state value of my sending_data structure.
For the ESPNow connection I've created following class:
Can anybody help?
#include "ESPConnection.h"
static const char *TAG = "ESPConnection";
void ESPConnection::get_master_mac(uint8_t *mac)
    uint8_t *master_mac = convert_mac_address(_master_mac);
    for (int i = 0; i < 6; i++)
        memcpy(&mac[i], &master_mac[i], sizeof(mac[i]));
void ESPConnection::init(uint32_t mode, esp_now_send_cb_t send_cb, esp_now_recv_cb_t receiv_cb)
    // Init Wifi
    init_wifi();
    // Init ESP32 Now
    init_esp32_now(mode, send_cb, receiv_cb);
/* WiFi should start before using ESPNOW */
void ESPConnection::init_wifi()
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    ESP_ERROR_CHECK(esp_wifi_set_mode(ESPNOW_WIFI_MODE));
    ESP_ERROR_CHECK(esp_wifi_start());
#if CONFIG_ESPNOW_ENABLE_LONG_RANGE
    ESP_ERROR_CHECK(esp_wifi_set_protocol(ESPNOW_WIFI_IF, WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N | WIFI_PROTOCOL_LR));
#endif
void ESPConnection::init_esp32_now(uint32_t mode, esp_now_send_cb_t send_cb, esp_now_recv_cb_t receiv_cb)
    ESP_ERROR_CHECK(esp_now_init());
    // Only send data
    if (mode == 1)
        // esp_now_register_send_cb(ESPConnection::on_alarm_data_sent);
        ESP_ERROR_CHECK(esp_now_register_send_cb(send_cb));
    // Only receive data
    else if (mode == 2)
        // esp_now_register_recv_cb(ESPConnection::on_alarm_data_received);
        ESP_ERROR_CHECK(esp_now_register_recv_cb(receiv_cb));
    // Send and receive data
    else if (mode == 3)
void ESPConnection::read_mac(uint8_t *mac)
    // unsigned char mac_base[6] = {0};
    // esp_efuse_mac_get_default(mac_base);
    // esp_read_mac(mac_base, ESP_MAC_WIFI_STA);
    // unsigned char mac_local_base[6] = {0};
    // unsigned char mac_uni_base[6] = {0};
    // esp_derive_local_mac(mac_local_base, mac_uni_base);
    esp_efuse_mac_get_default(mac);
    esp_read_mac(mac, ESP_MAC_WIFI_STA);
void ESPConnection::register_master(mac_address mac)
    // Register peer
    esp_now_peer_info_t peerInfo = {};
    peerInfo.channel = 0;
    peerInfo.encrypt = false;
    // peerInfo.ifidx = WIFI_IF_AP;
    uint8_t *converted_address = convert_mac_address(mac);
    memcpy(peerInfo.peer_addr, converted_address, 6);
    ESP_ERROR_CHECK(esp_now_add_peer(&peerInfo));
    // Store master
    _master_mac = mac;
void ESPConnection::register_slave(mac_address mac)
    // Register peer
    // uint8_t *converted_address = { 0 };
    // convert_mac_address(mac, converted_address);
    // Store slave to list
    _slave_mac_list.push_back(mac);
esp_err_t ESPConnection::send_data(const uint8_t *data)
    return esp_now_send(0, (uint8_t *)&data, sizeof(data));
uint8_t *ESPConnection::convert_mac_address(mac_address mac_address)
    static uint8_t mac[6] = {0, 0, 0, 0, 0, 0};
    mac[0] = mac_address.octet1;
    mac[1] = mac_address.octet2;
    mac[2] = mac_address.octet3;
    mac[3] = mac_address.octet4;
    mac[4] = mac_address.octet5;
    mac[5] = mac_address.octet6;
    return mac;
And here is my main file:
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include "nvs_flash.h"
#include "../components/esp_connection/ESPConnection.h"
#include "../components/trigger/Trigger.h"
static const char *TAG = "Example";
typedef enum
    MASTER,
    SLAVE,
} device_type_t;
typedef struct sending_data
    bool state;
} sending_data_t;
sending_data_t _sending_data;
Trigger _button_send_data = Trigger(GPIO_NUM_4);
device_type_t _device_type;
ESPConnection _esp;
uint8_t flash_mode;
void handle_device();
void handle_master_device();
void handle_slave_device();
void init_data();
void init_esp();
void on_sending_data_received(const uint8_t *mac, const uint8_t *incomingData, int len);
void on_sending_data_sent(const uint8_t *mac_addr, esp_now_send_status_t status);
void print_local_mac();
void print_mac(unsigned char mac[6]);
    if (_device_type == MASTER)
    else if (_device_type == SLAVE)
    ESP_LOGI(TAG, "Master device mode");
    if (_button_send_data.get_state() == true)
        _sending_data.state = true;
        _esp.send_data((uint8_t *)&_sending_data);
    ESP_LOGI(TAG, "Slave device mode");
void init_data()
    _sending_data = {0};
    _sending_data.state = {false};
void init_esp()
    // Initialize ESP_NOW
    _esp.init(3, on_sending_data_sent, on_sending_data_received);
        mac_address slave_mac;
        slave_mac.octet1 = 0x21;
        slave_mac.octet2 = 0x33;
        slave_mac.octet3 = 0x23;
        slave_mac.octet4 = 0x3d;
        slave_mac.octet5 = 0xd3;
        slave_mac.octet6 = 0x32;
        _esp.register_slave(slave_mac);
        slave_mac.octet5 = 0xe3;
        _esp.register_master(master_mac);
// Callback when data is received
    memcpy(&_sending_data, incomingData, sizeof(_sending_data));
    // sending_data_t *buf = (sending_data_t *)incomingData;
    // if (len < sizeof(sending_data_t))
    //     ESP_LOGE(TAG, "Receive ESPNOW data too short, len:%d", len);
    // ESP_LOGI(TAG, "Sending data state: %d", buf->state);
    // _sending_data.state = buf->state;
    ESP_LOGI(TAG, "Bytes received: %d", len);
    ESP_LOGI(TAG, "Sending data state: %d", _sending_data.state);
// Callback when data is sent
    char macStr[18];
    // Copies the sender mac address to a string
    snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
             mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
    ESP_LOGI(TAG, "Packet to: %s", macStr);
    ESP_LOGI(TAG, "Send status: %s", (status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail"));
    unsigned char mac[6] = {0};
    _esp.read_mac(mac);
    ESP_LOGI(TAG, "Local");
    print_mac(mac);
void print_master_mac()
    _esp.get_master_mac(mac);
    ESP_LOGI(TAG, "Master");
    print_mac(mac);
    char macStr[18];
             mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
    ESP_LOGI(TAG, "MAC: %s", macStr);
extern "C" void app_main()
#if CONFIG_DEVICE_MODE_MASTER == 1
    _device_type = MASTER;
#else
    _device_type = SLAVE;
#endif
    // Initialize NVS
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
    ESP_ERROR_CHECK(ret);
    // Init ESP
    init_esp();
    // Init data
    init_data();
    // Print MAC
    // print_local_mac();
    // print_master_mac();
    while (true)
        handle_device();
        vTaskDelay(1000 / portTICK_RATE_MS);
Rocket2022
Re: ESPNow - receiving wrong data
Postby Rocket2022 » Mon Jun 27, 2022 7:40 pm
Hello together,
I figured out that I always receive too long data.
Has someone a hint for me why the data is too long?
    if (len < sizeof(_sending_data))
    if (len > sizeof(_sending_data))
        ESP_LOGE(TAG, "Receive ESPNOW data too long, len:%d", len);
boarchuz
Postby boarchuz » Tue Jun 28, 2022 7:07 am
Instead of sending [sizeof(object that data points to)] bytes of [object that data points to], you are sending [sizeof(the data pointer itself)] bytes of [a pointer to the data pointer].
You would typically have a second parameter for the number of bytes to send (if its generic), or take a pointer to your data type.
esp_err_t ESPConnection::send_data(const uint8_t *data, size_t len)
    return esp_now_send(0, data, len);
// or
esp_err_t ESPConnection::send_data(const sending_data_t *data)
    return esp_now_send(0, (const uint8_t *)data, sizeof(*data));
Rocket2022
Postby Rocket2022 » Wed Jun 29, 2022 1:03 pm
Hi boarchuz,
you are totaly right!
Thanks a lot!
BR
Marco
Users browsing this forum: Baidu [Spider], Google [Bot] and 196 guests
