Hello everyone,
I am working with this library https://github.com/espressif/esp-serial-flasher and I am having troubles. In the examples>binaries folder there are the bootloader.bin, partition-table.bin and hello-world.bin . How can I know what partition table configuration has been used?
Thank you
ESP SERIAL FLASHER
ESP SERIAL FLASHER
Re: ESP SERIAL FLASHER
If you run 'idf.py build', one of the last lines gives you the command line you should use for esptool.py; it has the addresses to flash the binaries to mentioned in it.
