we are calling the
esp_ota_write(esp_ota_handle_t handle, const void *data, size_t size)
function with a buffer size of 1 byte, because we are receiving the firmware byte per byte.
Is it ok to do so, or will this lead to a faster wear of the flash, because only one byte is writte at one time?
Thanks,
Mike
Is it ok to call esp_ota_write() with buffer size of 1 byte?
Re: Is it ok to call esp_ota_write() with buffer size of 1 byte?
It will wear level flash faster for sure, because low level API is working with 4kB flash sectors (read/write).
It is much better to have temporary buffer which will be flashed after filling with 4kB of data or even with 1kB of data.
I disagree on the extra wear: generally flash *erases* is the thing that makes flash wear out, not flash *writes*. +1 on the temp buffer, but it may be that the OTA routines already have a buffer like that internally.
EDIT: Looked it up, ota has a buffer of 16 bytes. I don't think there's anything technically wrong with calling esp_ota_write every byte, but it is likely to be a lot faster if you feed it a big buffer instead.
Users browsing this forum: Bing [Bot], Hello1024, HitecSmartHome and 256 guests
