Good day everyone
I need help with narrowing the bandwith of ESPNow. It seems that the default bandwith is 40MHz, and this is causing it to encrouch onto the work Wifi. I do not want the two to interfere. The obvious solution was to put them on different channels, but our IT has networks on all major channels (6,11). The networks that are affected are the ones on channel 6. I have attached an image showing the networks we have here at work. Id be grateful if I can get help on how to adjust the bandwith or what alternatives I can try so that i do not get interference. On the Image, the ESPNow network is the one called "Forwarder".
Changing the bandwith of ESPnow
- ESPNow and Wifi band inteference.jpeg (67.36 KiB) Viewed 461 times
Users browsing this forum: endi83, Google [Bot] and 154 guests
