I want to change the default device name "BLUFI_DEVICE" of esp32 in this sample blufi project
https://github.com/espressif/esp-idf/tr ... ooth/blufi
I modified esp_err_t esp_blufi_host_init(void) in blufi_init.c like this
int ret;
ret = esp_bluedroid_init();
if (ret)
BLUFI_ERROR("%s init bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
return ESP_FAIL;
ret = esp_bluedroid_enable();
if (ret)
return ESP_FAIL;
// I supposed change device name should like this
ret = esp_bt_dev_set_device_name("test");
if (ret)
BLUFI_ERROR("%s bt dev set device name failed: %s\n", __func__, esp_err_to_name(ret));
return ESP_FAIL;
// end
BLUFI_INFO("BD ADDR 2 : " ESP_BD_ADDR_STR "\n", ESP_BD_ADDR_HEX(esp_bt_dev_get_address()));
return ESP_OK;
but esp_bt_dev_set_device_name("test") dosen't work at all.
It still appears the default name "BLUFI_DEVICE" on EspBlufi APP.
I am wondering if there is an esp-idf bug or some mistakes I've made that I didn't notice?
Thank you.
