Hey folks,
I am new to the esp world!
trying to setup a project I come across a problem, that can't solve and I'm freaking out.
I have the following project structure:
main.c contains following code:
#include "Includes.h"
void app_main(void){
SpiffsInit();
CMakeList.txt in main folder:
idf_component_register(
SRCS "main.c"
REQUIRES FileServer // tried also "FileServer.c", "../components/FileServer.c", and full path -> all the same result
INCLUDE_DIRS "."
"../components/include"
FileServer.c contains following code:
static const char* TAG = "FileServer";
esp_err_t SpiffsInit(void){
ESP_LOGI(TAG, "Initializing SPIFFS");
esp_vfs_spiffs_conf_t conf = {
.base_path = NameOfFS,
.partition_label = NULL,
.max_files = 5, // number of files that can be opened at the same time
.format_if_mount_failed = true
esp_err_t ret = esp_vfs_spiffs_register(&conf);
if(ret != ESP_OK) {
if(ret == ESP_FAIL){
ESP_LOGE(TAG, "Failed to mount or format filesystem");
else if(ret == ESP_ERR_NOT_FOUND) {
ESP_LOGE(TAG, "Failed to find SPIFFS partition");
else {
ESP_LOGE(TAG, "Failed to initialize SPIFFS (%s)", esp_err_to_name(ret));
return ESP_FAIL;
size_t total = 0, used = 0;
ret = esp_spiffs_info(NULL, &total, &used);
if(ret != ESP_OK) {
ESP_LOGE(TAG, "Failed to get SPIFFS partition information (%s)", esp_err_to_name(ret));
return ESP_FAIL;
ESP_LOGI(TAG, "Partition size: total: %d, used: %d", total, used);
return ESP_OK;
CMakeList.txt in components folder :
SRCS "FileServer.c"
INCLUDE_DIRS "include"
"C:/Espressif/esp-idf/components/hal/include/hal"
"C:/Espressif/esp-idf/components/spi_flash/include/"
"C:/Espressif/esp-idf/components/nvs_flash/include/"
"C:/Espressif/esp-idf/components/esp_http_server/include/"
"C:/Espressif/esp-idf/components/nghttp/port/include/"
EMBED_FILES "../components/SPIFFsImage/favicon.png"
"../components/SPIFFsImage/IndexHTML.html"
FileServer.h :
#ifndef __FILESERVER_H
#define __FILESERVER_H
esp_err_t SpiffsInit(void);
#endif
Includes.h:
#ifndef __INCLUDES_H
#define __INCLUDES_H
#include <sys/param.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/unistd.h>
#include <sys/stat.h>
#include <dirent.h>
#include <math.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_system.h"
#include "esp_log.h"
#include "esp_netif.h"
#include "esp_event.h"
#include "esp_wifi.h"
#include "C:/Espressif/esp-idf/components/spiffs/include/esp_spiffs.h"
#include "C:/Espressif/esp-idf/components/nvs_flash/include/nvs_flash.h"
#include "C:/Espressif/esp-idf/components/spi_flash/sim/stubs/vfs/include/esp_vfs.h"
#include "C:/Espressif/esp-idf/components/spi_flash/include/esp_partition.h"
#include "C:/Espressif/esp-idf/components/esp_http_server/include/esp_http_server.h"
#include "C:/Espressif/esp-idf/components/nghttp/port/include/http_parser.h"
#include "driver/gpio.h"
#include "FileServer.h"
#endif
Trying to build this ends up in following error:
[0/1] Re-running CMake...
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
CMake Error at C:/Espressif/esp-idf/tools/cmake/build.cmake:191 (message):
Failed to resolve component 'FileServer'.
C:/Espressif/esp-idf/tools/cmake/build.cmake:217 (__build_resolve_and_add_req)
C:/Espressif/esp-idf/tools/cmake/build.cmake:441 (__build_expand_requirements)
C:/Espressif/esp-idf/tools/cmake/project.cmake:399 (idf_build_process)
CMakeLists.txt:6 (project)
If I got the example in https://docs.espressif.com/projects/esp ... cmakelists right, than this should work!
What am I doing wrong?
Leaving the 'REQUIRED "FileServer.c" ' part away and moving 'SpiffsInit()' into main.c works flawlessley.
Problems with writing CMakeLists.txt for a project
- Mephisto75
I've changed your post title, if everyone would post under a title of 'Can please someone help me out !!!', we might as well do away with the concept of titles all together.
Now for your issue. I see a fair few things wrong with your setup:
- A component is a directory within the components/ folder. So if you want to make a component called 'FileServer', you would create the directory 'components/FileServer' in your project directory, and e.g. 'components/FileServer/CMakeLists.txt' as one of the files that live in that directory; your sources would also go there.
- You don't need to use 'INCLUDE_DIRS' to include paths from other components. The CMakeLists.txt of those components will take care of that for you.
- Instead of using EMBED_FILES to include files in a directory above yours, you could add a CMakeLists.txt file there to make that directory into a component without source, and embed the files that way.
- No need to #include absolute paths: the files you have there already are in your include paths (because the components that they belong to register those) and having absolute paths will break your project if you ever decide to share it or move directories around. So ' #include "C:/Espressif/esp-idf/components/spiffs/include/esp_spiffs.h"' -> '#include "esp_spiffs.h"'.
- Mephisto75
Re: Problems with writing CMakeLists.txt for a project
Thank you for the review!
Following your suggestions I am ending up with following project structure:
Makefile
CMakeLists.txt (project)
CMakeLists.txt (main)
main.c
CMakeLists.txt (components)
CMakeLists.txt (FileServer)
FileServer.c
FileServer.h
Includes.h
CMakeLists.txt (SPIFFsImage)
I've tried to implement your suggestions how I understood them but some how I am still missing a bit.
Trying to build the project leads to following error:
- .vscode
- build
- components
- CMakeLists.txt (components)
- include
- FileServer.h
- Includes.h
- FileServer
- CMakeLists.txt (FileServer)
- FileServer.c
- SPIFFsImage
- CMakeLists.txt (SPIFFsImage)
- IndexHTML.html
- main
- CMakeLists.txt (main)
- main.c
- CMakeLists.txt
- Makefile
- partition.csv
- sdkconfig
Makefile
- # This is a project Makefile. It is assumed the directory this Makefile resides in is a
- # project subdirectory.
- PROJECT_NAME := testproject
- include $(IDF_PATH)/make/project.mk
- SPIFFS_IMAGE_FLASH_IN_PROJECT := 1
- $(eval $(call spiffs_create_partition_image,storage,SPIFFsImage))
- # The following five lines of boilerplate have to be in your project's
- # CMakeLists in this exact order for cmake to work correctly
- cmake_minimum_required(VERSION 3.5)
- include($ENV{IDF_PATH}/tools/cmake/project.cmake)
- project(testproject)
- idf_component_register(
- SRCS "main.c"
- INCLUDE_DIRS "."
- #include "Includes.h"
- void app_main(void){
- SpiffsInit();
- INCLUDE_DIRS "include"
- SRCS "FileServer.c"
- INCLUDE_DIRS "."
- esp_err_t SpiffsInit(void){
- #ifndef __FILESERVER_H
- #define __FILESERVER_H
- esp_err_t SpiffsInit(void);
- #endif
- #ifndef __INCLUDES_H
- #define __INCLUDES_H
- #include <sys/param.h>
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <sys/unistd.h>
- #include <sys/stat.h>
- #include <dirent.h>
- #include <math.h>
- #include "freertos/FreeRTOS.h"
- #include "freertos/task.h"
- #include "freertos/queue.h"
- #include "freertos/event_groups.h"
- #include "esp_system.h"
- #include "esp_log.h"
- #include "esp_netif.h"
- #include "esp_event.h"
- #include "esp_wifi.h"
- #include "esp_spiffs.h"
- #include "nvs_flash.h"
- #include "esp_vfs.h"
- #include "esp_partition.h"
- #include "esp_http_server.h"
- #include "http_parser.h"
- #include "driver/gpio.h"
- #include "FileServer.h"
- #endif
- INCLUDE_DIRS "SPIFFsImage"
- FAILED: testproject.elf
- cmd.exe /C "cd . && C:\Espressif\.espressif\tools\xtensa-esp32-elf\esp-2021r2-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address @CMakeFiles\testproject.elf.rsp -o testproject.elf && cd ."
- c:/espressif/.espressif/tools/xtensa-esp32-elf/esp-2021r2-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj):(.literal.app_main+0x0): undefined reference to `SpiffsInit'
- c:/espressif/.espressif/tools/xtensa-esp32-elf/esp-2021r2-8.4.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `app_main':
- C:\Espressif\MyProjects\TestProject\build/../main/main.c:4: undefined reference to `SpiffsInit'
- collect2.exe: error: ld returned 1 exit status
- ninja: build stopped: subcommand failed.
You don't need a CMakeLists.txt in your component folder. Not sure if that's the source of the issue, but I'd try removing that first.
- Mephisto75
Just for the record!
Adding these two lines to CMakeLists.txt (main) worked for me!!
Everything else is as described in the previous post.
set(COMPONENT_SRCS "main.c" "../components/FileServer.c")
set(COMPONENT_ADD_INCLUDEDIRS "" "../components/")
register_component()
Users browsing this forum: No registered users and 149 guests
