Can't flash when PHY reset gpio is configured
glrtheil
Postby glrtheil » Tue Sep 13, 2022 5:12 pm
Using ESP32-WROOM-32UE. We've got a new board we've put a w5500 ethernet chip on and while it works great, there's an issue with flashing the board once the W5500 is active.
The W5500 reset pin is tied to GPIO 32. When configuring PHY, I provide this code
eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
phy_config.phy_addr = 1;
phy_config.reset_gpio_num = GPIO_NUM_32;
When this code is run, and while running I try to flash the ESP again, it will not flash unless I force it into bootloader mode. However, if I comment phy_config.reset_gpio_num, everything works as normal. Speaking to the guy who designed the hardware, we're a bit confused why I can't flash once that GPIO is set.
Is there any way past this issue without redesigning the board to use a different GPIO for PHY reset? I can provide schematics if necessary.
glrtheil
Re: Can't flash when PHY reset gpio is configured
Postby glrtheil » Fri Sep 16, 2022 1:33 pm
Bump. Badly need to figure out what the issue is here, and how we can overcome it.
ESP_ondrej
Postby ESP_ondrej » Tue Sep 20, 2022 7:59 am
Do you mean, you are not able to run `idf.py flash` and you need to press buttons or whatever to get into the download mode?
Could you please share your schematics?
glrtheil
Postby glrtheil » Wed Sep 21, 2022 6:40 pm
That's correct. Typically running flash just works since we added the 10uF capacitor on our board from EN to GND. However, once phy_config.reset_gpio_num is set to the correct GPIO, I can no longer flash without forcing the chip into bootloader mode.
Here's the schematic:
Ethernet Schematic w5500
esp_schematic
Postby ESP_Sprite » Thu Sep 22, 2022 12:15 am
I think your schematic pulls EN up hard when IO32 is high (through D1). I don't see your autoreset circuit, but it may not be able to sink enough current to get EN below the reset threshold with IO32 being high.
glrtheil
Postby glrtheil » Mon Sep 26, 2022 2:44 pm
Thanks for the info. We will research this and see if it's something we can overcome on the firmware side.
Users browsing this forum: No registered users and 266 guests
