generating text files to be embedded
nipil76
Postby nipil76 » Thu Oct 06, 2022 3:19 pm
I'm using ESP-IDF 4.4.2 in vscode without pio, using ESP-IDF extension, on windows 11
My whole project is public on github : https://github.com/nipil/open-fil-pilote-esp-idf
So far everything is fine and i can build my project in two steps using ESP-IDF terminal :
# generates autosign.crt and autosign.key from info.txt
cd .\components\ofp-certificates\
python gen.py
# build firmware and embed autosign.crt and autosign.key
cd -
idf.py.exe build
The current cmake file in the base folder :
cmake_minimum_required(VERSION 3.5)
set(EXTRA_COMPONENT_DIRS components/)
project(open-fil-pilote-esp-idf)
The current cmake file in the components/ofp-certificate folder
idf_component_register(
    EMBED_TXTFILES
        autosign.crt
        autosign.key
Now i want to automate the python gen.py command so that it is run implicitely during the build process, and eventually depend it on info.txt which is its input file, so that i only run it once.
But i cannot seem to do it, and it is driving me nuts...
Here is the my best attempt so far for the component's CMakeLists.txt :
    EMBED_TXTFILES
        autosign.crt
        autosign.key
add_custom_command(
  WORKING_DIRECTORY ${COMPONENT_DIR}
  OUTPUT autosign.crt autosign.key
  COMMAND python gen.py
  DEPENDS info.txt
add_custom_target(
  autosign
  DEPENDS autosign.crt autosign.key
add_dependencies(
  ${COMPONENT_TARGET}
  autosign
set_property(
  APPEND PROPERTY ADDITIONAL_MAKE_CLEAN_FILES autosign.crt autosign.key
No error, except the build system does not take my modification into account :
- the autosign.crt autosign.key files are not generated, and thus cannot be embedded
- the autosign.crt autosign.key are not cleaned either when cleaning the project
What am i missing ?
Any hint will be greatly appreciated !
Thanks in advance
Nicolas
ESP_igrr
Re: generating text files to be embedded
Postby ESP_igrr » Thu Oct 06, 2022 8:39 pm
Hi Nicolas,
The problem you are running into is related to the treatment of file names by add_custom_command CMake function.
According to the docs,
If an output name is a relative path it will be interpreted relative to the build tree directory corresponding to the current source directory.
So CMake is thinking that the command defined by your add_custom_command call will generate two files in the build directory: ${CMAKE_CURRENT_BINARY_DIR}/autosign.crt, ${CMAKE_CURRENT_BINARY_DIR}/autosign.key.
File names passed to idf_component_register are treated as relative to the current source directory. Since the files do not exist and there is no command to generate them, CMake produces this error.
To fix this, specify the absolute path to the generated files when calling add_custom_command:
add_custom_command(
  OUTPUT ${CMAKE_CURRENT_LIST_DIR}/autosign.crt ${CMAKE_CURRENT_LIST_DIR}/autosign.key
  DEPENDS info.txt
and it should work.
(However, you might consider keeping the generated files in the build directory, so that your source directory is always "clean". In that case, specify absolute path ${CMAKE_CURRENT_BINARY_DIR}/autosign.crt in EMBED_TXTFILES, instead.)
nipil76
Postby nipil76 » Sat Oct 08, 2022 7:36 am
That is .. .awesome. I didn't notice that line in the documentation about relative path (logically) using the current components' build directory as a base, that makes total sense.
I can confirm that both approach work for my project now :
1) Either outputing the generated files in the source component folder components/ofp-certificates (for developper convenience should he want to analyze it)with an additionnal property so they are removed when cleaning :
    EMBED_TXTFILES
    "autosign.crt"
    "autosign.key"
add_custom_command(
    OUTPUT ${COMPONENT_DIR}/autosign.crt ${COMPONENT_DIR}/autosign.key
    DEPENDS info.txt
add_custom_target(
    autosign
add_dependencies(
    ${COMPONENT_TARGET} autosign
set_property(
    APPEND PROPERTY ADDITIONAL_MAKE_CLEAN_FILES ${COMPONENT_DIR}/autosign.crt ${COMPONENT_DIR}/autosign.key
2) or outputting them in the binary component folder build/esp-idf/ofp-certificate for cleanliness, this time with no additionnal property is needed for cleaning as the folder is cleaned automatically
    EMBED_TXTFILES
add_custom_command(
    COMMAND python gen.py --infile ${COMPONENT_DIR}/info.txt --outdir=${CMAKE_CURRENT_BINARY_DIR}
    DEPENDS info.txt
add_custom_target(
    autosign
add_dependencies(
Thanks a bunch, this closes my case.
Have a nice day
Nicolas
Users browsing this forum: LSitar and 120 guests
