bridge from sta to ap
Hello all! This is my first post on this forum. Super happy you exists!
So have writed something with idea to share internet from wifi_sta to wifi_ap.. i know that exists in esp_iot_bridge and works, have tested. but i like to achive so this works. will paste code and output of program. i think all is writed correctly just ip addresses are not set as they need to be, i guess.
specialy for "br" interface. and when i try to set them manualy ip, netmask and gw stays 0.0.0.0 ... ok here is output of program and then code of program...:
output:
[0;32mI (219731) wifi kosAP: task_status() in the loop..[0m
[0;32mI (219741) wifi kosAP: esp_netif_get_dns_info() STA, err: ESP_OK, sta_dns: 80.58.61.254
[0m
[0;32mI (219751) wifi kosAP: esp_netif_get_dns_info() AP, err: ESP_OK, ap_dns: 0.0.0.0
[0m
[0;32mI (219761) wifi kosAP: esp_netif_get_dns_info() PORT, err: ESP_OK, port_dns: 80.58.61.254
[0m
[0;32mI (219761) wifi kosAP: esp_netif_get_dns_info() BR, err: ESP_OK, br_dns: 80.58.61.254
[0m
[0;32mI (219761) wifi kosAP: task_status() ap.ip: 192.168.4.1[0m
[0;32mI (219771) wifi kosAP: task_status() ap.netmask: 255.255.255.0[0m
[0;32mI (219781) wifi kosAP: task_status() ap.gw: 192.168.4.1[0m
[0;32mI (219781) wifi kosAP: task_status() ap.mac: 94:e6:86:02:8e:d9
[0m
[0;32mI (219791) wifi kosAP: task_status() sta.ip: 192.168.1.47[0m
[0;32mI (219801) wifi kosAP: task_status() sta.netmask: 255.255.255.0[0m
[0;32mI (219801) wifi kosAP: task_status() sta.gw: 192.168.1.1[0m
[0;32mI (219811) wifi kosAP: task_status() sta.mac: 94:e6:86:02:8e:d8
[0m
[0;32mI (219811) wifi kosAP: task_status() port.ip: 0.0.0.0[0m
[0;32mI (219821) wifi kosAP: task_status() port.netmask: 0.0.0.0[0m
[0;32mI (219831) wifi kosAP: task_status() port.gw: 0.0.0.0[0m
[0;32mI (219831) wifi kosAP: task_status() port.mac: 00:00:00:00:00:00
[0m
[0;32mI (219841) wifi kosAP: task_status() br.ip: 0.0.0.0[0m
[0;32mI (219841) wifi kosAP: task_status() br.netmask: 0.0.0.0[0m
[0;32mI (219851) wifi kosAP: task_status() br.gw: 0.0.0.0[0m
[0;32mI (219861) wifi kosAP: task_status() br.mac: 94:e6:86:02:8e:d8
program code:
/* soft APSTA by grandekos aka t3ch */
#include <string.h>
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_mac.h"
#include "esp_wifi.h"
#include "esp_wifi_netif.h"
//#include "esp_event.h"
#include "esp_log.h"
//#include "tcpip_adapter.h" replaced for esp_netif...
#include "esp_netif.h"
#include "esp_netif_br_glue.h"
//#include "esp_netif_lwip.h"
#include "esp_netif_net_stack.h"
#include "nvs_flash.h"
#include "driver/gpio.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#include "lwip/lwip_napt.h"
#include "dhcpserver/dhcpserver.h"
#include "dhcpserver/dhcpserver_options.h"
/* The examples use WiFi configuration that you can set via project configuration menu.
If you'd rather not, just change the below entries to strings with
the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_ESP_WIFI_SSID CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_ESP_WIFI_CHANNEL CONFIG_ESP_WIFI_CHANNEL
#define EXAMPLE_MAX_STA_CONN CONFIG_ESP_MAX_STA_CONN
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_WPA2_PSK
#define EXAMPLE_ESP_MAXIMUM_RETRY 10
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
esp_netif_t *ap = NULL, *sta = NULL, *port=NULL, *br=NULL;
esp_netif_ip_info_t sta_info, ap_info, port_info, br_info;
esp_netif_dns_info_t sta_dns, ap_dns, port_dns, br_dns;
TaskHandle_t task_handle = NULL;
/* The event group allows multiple bits for each event, but we only care about two events:
* - we are connected to the AP with an IP
* - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT BIT1
#if CONFIG_ESP_WIFI_AUTH_OPEN
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_OPEN
#elif CONFIG_ESP_WIFI_AUTH_WEP
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WEP
#elif CONFIG_ESP_WIFI_AUTH_WPA_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WAPI_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WAPI_PSK
#endif
static const char *TAG = "wifi kosAP";
static int s_retry_num=0;
void task_status() {
ESP_LOGI(TAG,"task_status() starting");
esp_err_t err;
uint8_t tmpmac[6];
while(1) {
ESP_LOGI(TAG,"task_status() in the loop..");
err = esp_netif_get_dns_info(sta, ESP_NETIF_DNS_MAIN, &sta_dns);
ESP_LOGI(TAG,"esp_netif_get_dns_info() STA, err: %s, sta_dns: "IPSTR"\n", esp_err_to_name(err), IP2STR(&sta_dns.ip.u_addr.ip4));
err = esp_netif_get_dns_info(ap, ESP_NETIF_DNS_MAIN, &ap_dns);
ESP_LOGI(TAG,"esp_netif_get_dns_info() AP, err: %s, ap_dns: "IPSTR"\n", esp_err_to_name(err), IP2STR(&ap_dns.ip.u_addr.ip4));
err = esp_netif_get_dns_info(port, ESP_NETIF_DNS_MAIN, &port_dns);
ESP_LOGI(TAG,"esp_netif_get_dns_info() PORT, err: %s, port_dns: "IPSTR"\n", esp_err_to_name(err), IP2STR(&port_dns.ip.u_addr.ip4));
err = esp_netif_get_dns_info(br, ESP_NETIF_DNS_MAIN, &br_dns);
ESP_LOGI(TAG,"esp_netif_get_dns_info() BR, err: %s, br_dns: "IPSTR"\n", esp_err_to_name(err), IP2STR(&br_dns.ip.u_addr.ip4));
esp_netif_get_ip_info(ap,&ap_info);
ESP_LOGI(TAG,"task_status() ap.ip: "IPSTR,IP2STR(&ap_info.ip));
ESP_LOGI(TAG,"task_status() ap.netmask: "IPSTR,IP2STR(&ap_info.netmask));
ESP_LOGI(TAG,"task_status() ap.gw: "IPSTR,IP2STR(&ap_info.gw));
esp_netif_get_mac(ap,&tmpmac);
ESP_LOGI(TAG,"task_status() ap.mac: "MACSTR"\n",MAC2STR(tmpmac));
esp_netif_get_ip_info(sta,&sta_info);
ESP_LOGI(TAG,"task_status() sta.ip: "IPSTR,IP2STR(&sta_info.ip));
ESP_LOGI(TAG,"task_status() sta.netmask: "IPSTR,IP2STR(&sta_info.netmask));
ESP_LOGI(TAG,"task_status() sta.gw: "IPSTR,IP2STR(&sta_info.gw));
esp_netif_get_mac(sta,&tmpmac);
ESP_LOGI(TAG,"task_status() sta.mac: "MACSTR"\n",MAC2STR(tmpmac));
esp_netif_get_ip_info(port,&port_info);
ESP_LOGI(TAG,"task_status() port.ip: "IPSTR,IP2STR(&port_info.ip));
ESP_LOGI(TAG,"task_status() port.netmask: "IPSTR,IP2STR(&port_info.netmask));
ESP_LOGI(TAG,"task_status() port.gw: "IPSTR,IP2STR(&port_info.gw));
esp_netif_get_mac(port,&tmpmac);
ESP_LOGI(TAG,"task_status() port.mac: "MACSTR"\n",MAC2STR(tmpmac));
esp_netif_get_ip_info(br,&br_info);
ESP_LOGI(TAG,"task_status() br.ip: "IPSTR,IP2STR(&br_info.ip));
ESP_LOGI(TAG,"task_status() br.netmask: "IPSTR,IP2STR(&br_info.netmask));
ESP_LOGI(TAG,"task_status() br.gw: "IPSTR,IP2STR(&br_info.gw));
esp_netif_get_mac(br,&tmpmac);
ESP_LOGI(TAG,"task_status() br.mac: "MACSTR"\n",MAC2STR(tmpmac));
vTaskDelay(3000/10);
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data){
if (event_id == WIFI_EVENT_AP_STACONNECTED) {
wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" join, AID=%d", MAC2STR(event->mac), event->aid);
esp_netif_dhcps_stop( ap );
esp_netif_dhcps_start( ap );
//esp_netif_dhcps_start( ap );
//esp_netif_dhcps_start( sta );
ESP_LOGI(TAG, "station "MACSTR" join -> dhcp restarted!, AID=%d", MAC2STR(event->mac), event->aid);
else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) {
wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data;
ESP_LOGI(TAG, "station "MACSTR" leave, AID=%d",
else if (event_id == WIFI_EVENT_STA_START) {
ESP_LOGI(TAG,"sta started, wifi connecting...");
esp_wifi_connect();
else if (event_id == WIFI_EVENT_STA_DISCONNECTED) {
if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
esp_wifi_connect();
s_retry_num++;
ESP_LOGI(TAG, "retry to connect to the AP");
} else {
xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
ESP_LOGI(TAG,"connect to the AP fail");
else if (event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
s_retry_num = 0;
xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
/*else if(event_id==SYSTEM_EVENT_AP_START) {
ESP_LOGI(TAG,"system event ap START!");
else if(event_id==SYSTEM_EVENT_STA_START) {
else {
ESP_LOGI(TAG,"Unknown event...%ld",event_id);
void wifi_init_softap(void)
esp_err_t err;
//esp_netif_dns_info_t ip_dns;
esp_netif_dhcp_status_t status;
s_wifi_event_group = xEventGroupCreate();
esp_event_loop_create_default();
ESP_ERROR_CHECK(esp_netif_init());
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
sta = esp_netif_create_default_wifi_sta();
//esp_netif_create_default_wifi_mesh_netifs(&sta, &ap);
/*-- Set static ip for station
esp_netif_ip_info_t ip_info;
IP4_ADDR(&ip_info.ip, 192, 168, 15, 22);
IP4_ADDR(&ip_info.gw, 192, 168, 15, 1);
IP4_ADDR(&ip_info.netmask, 255, 255, 255, 0);
esp_netif_set_ip_info(sta, &ip_info);
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
NULL));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
ESP_EVENT_ANY_ID,
NULL,
NULL/*&instance_got_ip*/));
wifi_config_t wifi_config_sta = {
.sta = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.password = EXAMPLE_ESP_WIFI_PASS,
.threshold.authmode = ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD,
//.sae_pwe_h2e = WPA3_SAE_PWE_BOTH,
.pmf_cfg = {
.capable = true,
.required = false
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config_sta));
ESP_ERROR_CHECK(esp_wifi_start());
/* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
* number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
pdFALSE,
pdFALSE,
portMAX_DELAY);
/* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
* happened. */
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
} else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
} else {
ESP_LOGE(TAG, "UNEXPECTED EVENT");
ESP_LOGI(TAG,"esp_netif_get_ip_info() sta done...");
printf("esp_netif_get_ip_info() sta ip: "IPSTR"\n",IP2STR(&sta_info.ip));
vTaskDelay( 3000/10 );
ESP_LOGI(TAG,"%s.) Test retrive sta iodriver... sta: %p", __func__, sta);
wifi_netif_driver_t sta_drv = esp_netif_get_io_driver(sta);
//wifi_netif_driver_t ap_drv = esp_netif_get_io_driver(ap);
uint8_t sta_mac[6], ap_mac[6];
err = esp_wifi_get_if_mac(sta_drv,sta_mac);
ESP_LOGI(TAG,"Test iodriver... sta_mac: "MACSTR"\n",MAC2STR(sta_mac));
//err = esp_wifi_get_if_mac(ap_drv,ap_mac);
//ESP_LOGI(TAG,"Test iodriver... ap_mac: "MACSTR"\n",MAC2STR(ap_mac));
//-- CREATE BRIDGE
// mac example:
// uint8_t new_mac[8] = {0x01,0x02,0x03,0x04,0x05,0x06};
// Create instances of esp-netif for Ethernet ports
esp_netif_inherent_config_t esp_netif_config = ESP_NETIF_INHERENT_DEFAULT_WIFI_STA();
esp_netif_config_t netif_cfg = {
.base = &esp_netif_config,
.stack = ESP_NETIF_NETSTACK_DEFAULT_WIFI_STA
esp_netif_config.if_key = "WLAN_0";
esp_netif_config.if_desc = "wlan0";
esp_netif_config.route_prio = 50;
esp_netif_config.flags = 0; // esp-netif flags need to be zero when port's to be bridged
port = esp_netif_new(&netif_cfg);
// Attach Ethernet driver to TCP/IP stack
ESP_ERROR_CHECK(esp_netif_attach(port, sta_drv));
// Create instance of esp-netif for bridge interface
esp_netif_inherent_config_t esp_netif_br_config = ESP_NETIF_INHERENT_DEFAULT_BR();
esp_netif_config_t netif_br_cfg = {
.base = &esp_netif_br_config,
.stack = ESP_NETIF_NETSTACK_DEFAULT_BR,
// Bridge configuration
bridgeif_config_t bridgeif_config = {
.max_fdb_dyn_entries = 10, // maximum number of address entries in dynamic forwarding database
.max_fdb_sta_entries = 2, // maximum number of address entries in static forwarding database
.max_ports = 1 // maximum number of ports the bridge can consist of
esp_netif_br_config.bridge_info = &bridgeif_config;
// Set MAC address of bridge interface the same as the Ethernet interface
//memcpy(esp_netif_br_config.mac, sta_mac, 6);
br = esp_netif_new(&netif_br_cfg);
/*esp_netif_ip_info_t br_info;
IP4_ADDR(&br_info.ip, 192, 168, 5, 1);
IP4_ADDR(&br_info.gw, 192, 168, 5, 1);
IP4_ADDR(&br_info.netmask, 255, 255, 255, 0);
esp_netif_set_ip_info(br, &br_info);*/
esp_netif_set_mac(br,sta_mac);
// Create new esp netif bridge glue instance
esp_netif_br_glue_handle_t netif_br_glue = esp_netif_br_glue_new();
// Add Ethernet port interfaces to that esp netif bridge glue instance
//for (int i = 0; i < eth_port_cnt; i++) {
// ESP_ERROR_CHECK(esp_netif_br_glue_add_port(netif_br_glue, eth_netifs));
ESP_ERROR_CHECK(esp_netif_br_glue_add_port(netif_br_glue, port));
// Attach esp netif bridge glue instance with added ports to bridge netif
ESP_ERROR_CHECK(esp_netif_attach(br, netif_br_glue));
esp_netif_dhcps_stop( br );
esp_netif_dhcps_start( br );
//-- CREATE & START WIFI AP
ap = esp_netif_create_default_wifi_ap();
ESP_LOGI(TAG,"esp_netif_create_default_wifi_ap(), sleeping 3s...");
ESP_LOGI(TAG,"esp_netif_get_ip_info() ap done...");
printf("esp_netif_get_ip_info() ap ip: "IPSTR"\n",IP2STR(&ap_info.ip));
/*dhcps_lease_t dhcps_poll = {
.enable = true
uint32_t len = sizeof(dhcps_poll);
IP4_ADDR(&dhcps_poll.start_ip, 192, 168, 4, 2);
IP4_ADDR(&dhcps_poll.end_ip, 192, 168, 4, 10);
esp_netif_dhcps_option(ap, ESP_NETIF_OP_SET, REQUESTED_IP_ADDRESS, &dhcps_poll, len);*/
// init two mesh network interfaces
/*esp_netif_dhcpc_get_status(sta, &state);
esp_netif_dhcps_get_status(ap, &state);
// test both server and client are still *not* STARTED after start
esp_netif_action_start(ap, NULL, 0, NULL);
esp_netif_action_start(sta, NULL, 0, NULL);
esp_netif_dhcps_get_status(ap, &state);*/
wifi_config_t wifi_config_ap = {
.ap = {
.ssid = "t3ch_ap",
.ssid_len = strlen("t3ch_ap"),
.channel = 6,
.password = "t3ch_ap1",
.max_connection = 4,
.authmode = WIFI_AUTH_WPA_WPA2_PSK,
.pmf_cfg = {
.required = false,
//if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
// wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config_ap));
/*err = esp_netif_dhcps_stop( ap );
ESP_LOGI(TAG,"esp_netif_dhcps_stop() ap, err: %s", esp_err_to_name(err));
esp_netif_ip_info_t ap_info;
IP4_ADDR(&ap_info.ip, 192, 168, 4, 1);
IP4_ADDR(&ap_info.gw, 192, 168, 1, 1);
IP4_ADDR(&ap_info.netmask, 255, 255, 255, 0);
esp_netif_set_ip_info(ap, &ap_info);
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s channel:%d",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS, EXAMPLE_ESP_WIFI_CHANNEL);
err = esp_netif_dhcps_stop( sta );
ESP_LOGI(TAG,"esp_netif_dhcps_stop() sta, err: %s", esp_err_to_name(err));
err = esp_netif_dhcps_start( ap );
ESP_LOGI(TAG,"esp_netif_dhcps_start() ap, err: %s", esp_err_to_name(err));
err = esp_netif_dhcps_start( sta );
ESP_LOGI(TAG,"esp_netif_dhcps_start() sta, err: %s", esp_err_to_name(err));
ESP_LOGI(TAG, "Starting task_status!!!");
xTaskCreate( task_status, "NAME", 5000, NULL, tskIDLE_PRIORITY, &task_handle );
void app_main(void)
//Initialize NVS
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_AP");
wifi_init_softap();
A lot thanks!!!
t3ch
output:
[0m
[0m
[0m
[0m
[0m
[0m
[0m
program code:
#include <string.h>
#endif
esp_err_t err;
uint8_t tmpmac[6];
while(1) {
esp_wifi_connect();
esp_wifi_connect();
s_retry_num++;
} else {
s_retry_num = 0;
else {
esp_err_t err;
ESP_EVENT_ANY_ID,
NULL,
NULL));
ESP_EVENT_ANY_ID,
NULL,
.sta = {
.pmf_cfg = {
.capable = true,
.required = false
pdFALSE,
pdFALSE,
portMAX_DELAY);
* happened. */
} else {
//-- CREATE BRIDGE
// mac example:
.enable = true
.ap = {
.ssid = "t3ch_ap",
.channel = 6,
.pmf_cfg = {
.required = false,
void app_main(void)
//Initialize NVS
wifi_init_softap();
A lot thanks!!!
t3ch
Re: bridge from sta to ap
now have updated few things. now can ping client conected to ap and ap that is station is connected to but client still dont have access to web..
here some outputs and will put code to git soon:
ping 192.168.1.1
parseipaddr() starting 192.168.1.1
parseipaddr() d1esp> 56 bytes from 192.168.1.1 icmp_seq=1 ttl=64 time=6 ms
56 bytes from 192.168.1.1 icmp_seq=2 ttl=64 time=4 ms
56 bytes from 192.168.1.1 icmp_seq=3 ttl=64 time=5 ms
56 bytes from 192.168.1.1 icmp_seq=4 ttl=64 time=6 ms
--- 192.168.1.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 21ms
esp> ping 192.168.4.2
parseipaddr() starting 192.168.4.2
parseipaddr() d1esp> 56 bytes from 192.168.4.2 icmp_seq=1 ttl=64 time=74 ms
56 bytes from 192.168.4.2 icmp_seq=2 ttl=64 time=101 ms
56 bytes from 192.168.4.2 icmp_seq=3 ttl=64 time=21 ms
56 bytes from 192.168.4.2 icmp_seq=4 ttl=64 time=45 ms
--- 192.168.4.2 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 241ms
ping google.com
parseipaddr() starting google.com
parseipaddr() d1esp> 56 bytes from 142.250.184.174 icmp_seq=1 ttl=116 time=35 ms
56 bytes from 142.250.184.174 icmp_seq=2 ttl=116 time=34 ms
56 bytes from 142.250.184.174 icmp_seq=3 ttl=116 time=32 ms
56 bytes from 142.250.184.174 icmp_seq=4 ttl=116 time=38 ms
ping 192.168.1.43
parseipaddr() starting 192.168.1.43
parseipaddr() d1esp> 56 bytes from 192.168.1.43 icmp_seq=1 ttl=64 time=11 ms
56 bytes from 192.168.1.43 icmp_seq=2 ttl=64 time=3 ms
56 bytes from 192.168.1.43 icmp_seq=3 ttl=64 time=5 ms
56 bytes from 192.168.1.43 icmp_seq=4 ttl=64 time=2 ms
--- 192.168.1.43 ping statistics ---
status
[0;32mI (274499) wifi kosAP: do_cmd_status() starting[0m
[0;32mI (274499) wifi kosAP: do_cmd_status() esp_netif_get_dns_info() STA, err: ESP_OK, sta_dns: 80.58.61.254
[0m
[0;32mI (274519) wifi kosAP: do_cmd_status() esp_netif_get_dns_info() AP, err: ESP_OK, ap_dns: 114.114.114.114
[0m
[0;32mI (274519) wifi kosAP: do_cmd_status() ap.ip: 192.168.4.1[0m
[0;32mI (274529) wifi kosAP: do_cmd_status() ap.netmask: 255.255.255.0[0m
[0;32mI (274529) wifi kosAP: do_cmd_status() ap.gw: 192.168.4.1[0m
[0;32mI (274549) wifi kosAP: do_cmd_status() ap.mac: 94:e6:86:02:8e:d9
[0m
[0;32mI (274549) wifi kosAP: do_cmd_status() sta.ip: 192.168.1.47[0m
[0;32mI (274559) wifi kosAP: do_cmd_status() sta.netmask: 255.255.255.0[0m
[0;32mI (274559) wifi kosAP: do_cmd_status() sta.gw: 192.168.1.1[0m
[0;32mI (274569) wifi kosAP: do_cmd_status() sta.mac: 94:e6:86:02:8e:d8
[0m
esp>
ping 192.168.1.1
ping google.com
ping 192.168.1.43
status
[0m
[0m
[0m
[0m
esp>
and bridging have removed and included ip_napt_enable(..) which give me options to ping clients on ap. without this you can not. so one problem left only. access to web for clients.. noticing with git repo soon
can ping from device connected to ap for example
device ip: 192.168.4.2 (mobile)
router out web: 192.168.1.1 <-- this can not ping
this can ping: 192.168.1.47 ??
maybe i should change gateway or mask or something?
when i debug esp-ios-bridge i see there they use only two interfaces to share connection and same mac_s and all same.. so i realy dont understand why the f..k my thing dont wana work.. so for now i am debugging and using esp-ios-bridge with mine additions, updates what ever we call that. noticing here with git repo when is up.. *** what i think is possible my sequence of configuration of interfaces is not correct..
love you all ***
love you all ***
Sorry, I'm reading along but can't really help. It's odd that a ping works but a website request does not. FWIW your netmasks look correct to me.
AFAIK, bridging between STA and AP is not possible with the ESP32. Only ETH <-> AP.
Of course, you can use NAT, but not real bridge mode between STA and AP.
So, the devices connected to the AP have to be in a different subnet than your router.
ESP32 / ESP-IDF 5.1.3
thans guys. now i have managed with esp-iot-bridge. here is my version on github
https://github.com/m5it/esp-kos-bridge
what have added is in main/t3ch_* files.. some code removed. will remove more i guess. not sure.
today have thinking and i guess it can be connected with ARP and maybe if we spoof and redirect dns server like this? then.. it will work without special coding..?
Users browsing this forum: No registered users and 257 guests
