Dear Sirs:
The MDNS is isolated for idf v5.0 and hence I downloaded the esp-protocols from https://github.com/espressif/esp-protocols for mdns.
but, I don't know how to correctly use the package, I always get fail when I use eclipse to build it.
Could anyone tell me how to correctly use esp-protocols package, please?
Thank you.
[Solved]How to build "esp-protocols" package for idf v5.0
Re: How to build "esp-protocols" package for idf v5.0
Please see guidelines for IDF removed components here: https://docs.espressif.com/projects/esp ... nents.html
For mdns case, you can add this component to your project by following command:
idf.py add-dependency espressif/mdns^1.0.7
Mahavir
https://github.com/mahavirj/
Dear ESP_Mahavir:
Thank you very very much to reply to me, I see the URL your mentioned before I pose this question.
But I'm confused,
For v4.4.3, I can use eclipse (new->New Project->ESP IDF Project->from ESP IDF template) to open a ESP32S3 project, because mdns example already exists in the template list.
For v5.0, I don't know how to use eclipse to add the MDNS example, I try to do it as below.
1. Download esp-protocols package
2. copy common_components & components/mdns to C:\Espressif\frameworks\esp-idf-v5.0\componests
3. copy esp-protocols\components\mdns\examples to C:\Espressif\frameworks\esp-idf-v5.0\examples
4. use new->New Project->ESP IDF Project->from ESP IDF template for mdns
5. I got build error.
Do you know how to integrate the package for eclipse?
Sorry, I'm not smart.
But I'm confused,
Dear ESP_Mahavir:
Thanks for advising, finally I built the example successfully.
The steps are as below.
1. Execute Eclipse
2. File->New->Espressif IDF Project to create a empty ESP32 project and name project to mdns
3. At this moment, "Install ESP-IDF components." does not show after the mouse right click.
4. Build this project.
5. "Install ESP-IDF components." could be shown after the mouse right click, when the project build is completed.
6. Then I copy all files from esp-protocols-master\components\mdns\examples to the working project folder.
7. rebuild again, I got successful, and the MDNS function works well.
BTW, If I open the example project folder by the eclipse, it cannot be recognized as ESP Project, so I cannot select the launch target to esp, how can I do to solve it?
thanks very much.
1. Execute Eclipse
thanks very much.
Users browsing this forum: Bing [Bot] and 86 guests
