I'd like to know if VP and VN could be use as normal pins when used as ADC1_0, ADC1_3, RTC, GPIO input only.
I ask this because from here viewtopic.php?t=3206 and from other topics I understand that something has changed about the use of S_VP and S_VN.
I only care about if they work as well as the other pins.
[SOLVED] VP and VN pins on ESP32-WROOM-32
Filippo
Re: VP and VN pins on ESP32-WROOM-32
That is answered in the data sheet.
https://www.espressif.com/sites/default ... eet_en.pdf
From page 15 and 56 of the datasheet I read that there is nothing strange on those pin, they are only input without pull-up/down.username wrote: ↑Sat Dec 24, 2022 12:41 amThat is answered in the data sheet.
I didn't read nothing more here, that's why I choose to write on this forum.
Can you confirm that they are "normal" pins?
Filippo
What is your definition of a "normal" pin?Can you confirm that they are "normal" pins?
I mean a pin that doesn't hide something, e.g. some kind of inefficiency
Filippo
However I think you answered here Thanksusername wrote: ↑Sat Dec 24, 2022 12:41 amThat is answered in the data sheet.
Filippo
Users browsing this forum: hdsjulian2 and 235 guests
