dns can't update dest IP when using 2 AP(wifi router)
luisfynn
Postby luisfynn » Fri Dec 30, 2022 1:45 am
hello. I am luis.
I use IDF_V4.4.1
I try to send some file using WIFI
I use 2AP(wifi router)
First My esp has connected AP(wifi router)-A and send file to dest.
and 1minute later, My esp has connected AP(wifi router)-B and send file to dest(same dest) but dest ip doesnt update ..
My esp has 172.20.10.2 but dest ip has 192.168.1.72(previous ip). how to solve this ??? please help me
I (21753) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (24253) esp_netif_handlers: sta ip: 192.168.0.5, mask: 255.255.255.0, gw: 192.168.0.1
I (24253) BF_WIFI*: got ip:192.168.0.5
I (24253) BF_WIFI*: WI-FI connect bit result: 0x1
I (24253) BF_WIFI*: connected to ap SSID:RnD_Office password:body_rnd
W (24263) APP_MAIN: [BleWifiConnTask]Success to connect WIFI
I (24273) APP_MAIN: WIFI_Total_SendJson
W (24273) HTTP_CLIENT: max_redirection_count 50
I (24283) APP_MAIN: [WIFI_Total_Http_Send]success to esp_http_client_init
W (24283) HTTP_CLIENT: set post file length = 36
W (24293) HTTP_CLIENT: Begin connect to: https://log.bodyfriend.co.kr:443
W (24303) esp-tls: host:log.bodyfriend.co.kr: strlen 20
W (24323) wifi:<ba-add>idx:0 (ifx:0, 58:86:94:9b:16:50), tid:0, ssn:2, winSize:64
W (24333) esp-tls: addrinfo->ai_family == AF_INET
W (24333) esp-tls: [sock=-1] Resolved IPv4 address: 192.168.1.72
W (24343) esp-tls: [esp_tcp_connect]fd 54 addrinfo->ai_addrlen 28
W (24343) esp-tls: connecting...
W (24513) esp-tls: handshake in progress...
W (25523) HTTP_CLIENT: Begin connect to: https://log.bodyfriend.co.kr:443
W (25523) esp-tls: handshake in progress...
W (27353) HTTP_CLIENT: Begin connect to: https://log.bodyfriend.co.kr:443
W (27353) esp-tls: handshake in progress...
W (27353) BF_WIFI*: HTTP_EVENT_ON_CONNECTED
W (27353) BF_WIFI*: HTTP_EVENT_HEADER_SENT
W (28713) BF_WIFI*: HTTP_EVENT_ON_HEADER, key=Server, value=nginx
W (28713) BF_WIFI*: HTTP_EVENT_ON_HEADER, key=Date, value=Wed, 28 Dec 2022 10:23:01 GMT
W (28713) BF_WIFI*: HTTP_EVENT_ON_HEADER, key=Content-Type, value=application/json;charset=UTF-8
W (28723) BF_WIFI*: HTTP_EVENT_ON_HEADER, key=Transfer-Encoding, value=chunked
W (28733) BF_WIFI*: HTTP_EVENT_ON_HEADER, key=Connection, value=keep-alive
W (28743) BF_WIFI*: HTTP_EVENT_ON_DATA, len=57
W (28743) BF_WIFI*: HTTP_EVENT_ON_FINISH
I (28753) APP_MAIN: HTTPS Status = 200, content_length = -1
I (28753) BF_WIFI*: bf_wifi_connect.c
		-http_event_handler():
		-HTTP_EVENT_DISCONNECTED:
E (28773) APP_MAIN: Success to send testdata
W (28773) APP_MAIN: [BleWifiConnTask]Success to send data to server
I (28783) wifi:state: run -> init (0)
I (28783) wifi:pm stop, total sleep time: 5397351 us / 7101130 us
W (28783) wifi:<ba-del>idx
I (28793) wifi:new:<3,0>, old:<3,1>, ap:<255,255>, sta:<3,1>, prof:1
W (28803) wifi:hmac tx: ifx0 stop, discard
I (28853) wifi:flush txq
I (28853) wifi:stop sw txq
I (28853) wifi:lmac stop hw txq
I (28853) wifi:Deinit lldesc rx mblock:10
I (28863) APP_MAIN: [WIFI_Total_Stop]Destroy g_bf_myAP
W (28863) APP_MAIN: Delete BleWifiConnTask
I (94753) BLE_APP: ESP_GATTS_RESPONSE_EVT handle 0x00, status 0
I (94763) RECV BLE DATA: 0x3f815f70   24 41 44 01 07 01 b2                              |$AD....|
W (94763) RUN_MODE1: [BLE] BleHead1 : 0, packet size: 7
W (94773) RUN_MODE1: [BLE] BleHead2 : 0 msg.data_len: 7, msg.checksum: 178, cal.checksum: 178
I (94783) COPY BLE DATA: 0x3ffc47d4   24 41 44 01 07 01 b2                              |$AD....|
W (94783) RUN_MODE1: [BLE] Data : $AD²
W (94793) RUN_MODE1: [BLE] Run process, 0x1
W (94793) esp_netif_lwip: esp-netif has been successfully initialized
W (94803) event: created task for loop 0x3ffe3a40
W (94813) event: created event loop 0x3ffe3a40
I (94823) wifi:wifi driver task: 3ffcf600, prio:23, stack:6656, core=0
I (94833) wifi:wifi firmware version: eb52264
I (94833) wifi:wifi certification version: v7.0
I (94833) wifi:config NVS flash: enabled
I (94833) wifi:config nano formating: disabled
I (94843) wifi:Init data frame dynamic rx buffer num: 32
I (94843) wifi:Init management frame dynamic rx buffer num: 32
I (94853) wifi:Init management short buffer num: 32
I (94853) wifi:Init static tx buffer num: 16
I (94863) wifi:Init tx cache buffer num: 32
I (94863) wifi:Init static rx buffer size: 1600
I (94863) wifi:Init static rx buffer num: 10
I (94873) wifi:Init dynamic rx buffer num: 32
I (94873) wifi_init: rx ba win: 16
I (94883) wifi_init: tcpip mbox: 32
I (94883) wifi_init: udp mbox: 6
I (94883) wifi_init: tcp mbox: 6
I (94893) wifi_init: tcp tx win: 5744
I (94893) wifi_init: tcp rx win: 5744
I (94903) wifi_init: tcp mss: 1436
I (94903) wifi_init: WiFi/LWIP prefer SPIRAM
I (94913) wifi:mode : sta (c4:dd:57:6a:a0:0c)
I (94913) wifi:enable tsf
I (98113) APP_MAIN: Total APs scanned = 21
I (98113) APP_MAIN: SSID 		LuisIphone
I (98113) APP_MAIN: RSSI 		-32
I (98113) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98113) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98123) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98123) APP_MAIN: Channel 		6
I (98133) APP_MAIN: SSID 		RnD_Office
I (98133) APP_MAIN: RSSI 		-59
I (98143) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98143) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98153) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98153) APP_MAIN: Channel 		3
I (98163) APP_MAIN: SSID 		design
I (98163) APP_MAIN: RSSI 		-60
I (98173) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98173) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98183) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98183) APP_MAIN: Channel 		1
I (98193) APP_MAIN: SSID 		AT_401_CST_570004_WW_ed08
I (98193) APP_MAIN: RSSI 		-62
I (98203) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98203) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98213) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98213) APP_MAIN: Channel 		11
I (98223) APP_MAIN: SSID 		AT_401_CST_570004_WW_ed14
I (98223) APP_MAIN: RSSI 		-71
I (98233) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98233) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98243) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98243) APP_MAIN: Channel 		11
I (98253) APP_MAIN: SSID 		CEO
I (98253) APP_MAIN: RSSI 		-73
I (98263) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98263) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98273) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98273) APP_MAIN: Channel 		2
I (98283) APP_MAIN: SSID 		AT_401_CST_570004_WW_9c39
I (98283) APP_MAIN: RSSI 		-74
I (98293) APP_MAIN: Authmode 	WIFI_AUTH_WPA2_PSK
I (98293) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98303) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98303) APP_MAIN: Channel 		11
I (98313) APP_MAIN: SSID 		telecop
I (98313) APP_MAIN: RSSI 		-75
I (98323) APP_MAIN: Authmode 	WIFI_AUTH_WPA_WPA2_PSK
I (98323) APP_MAIN: Pairwise Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98333) APP_MAIN: Group Cipher 	WIFI_CIPHER_TYPE_CCMP
I (98333) APP_MAIN: Channel 		2
I (98343) APP_MAIN: Size: 33
I (98343) APP_MAIN: SSID 		LuisIphone
I (98353) APP_MAIN: SSID 		RnD_Office
I (98353) APP_MAIN: SSID 		design
I (98353) APP_MAIN: SSID 		AT_401_CST_570004_WW_ed08
I (98363) APP_MAIN: SSID 		AT_401_CST_570004_WW_ed14
I (98373) APP_MAIN: SSID 		CEO
I (98373) APP_MAIN: SSID 		AT_401_CST_570004_WW_9c39
I (98383) APP_MAIN: SSID 		telecop
I (98383) wifi:flush txq
I (98383) wifi:stop sw txq
I (98383) wifi:lmac stop hw txq
I (98393) wifi:Deinit lldesc rx mblock:10
I (98403) APP_MAIN: [WIFI_Total_Stop]Destroy g_bf_myAP
W (98403) RUN_MODE1: [BLE] BleHead3 : 0
W (98403) RUN_MODE1: [BLE] BleHead4 : 1
I (103513) BLE_APP: ESP_GATTS_RESPONSE_EVT handle 0x226c, status 0
I (103523) RECV BLE DATA: 0x3f815f70   24 41 44 06 42 4c 75 69  73 49 70 68 6f 6e 65 ff  |$AD.BLuisIphone.|
I (103523) RECV BLE DATA: 0x3f815f80   ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
I (103533) RECV BLE DATA: 0x3f815f90   ff ff ff 31 31 31 31 32  32 32 32 ff ff ff ff ff  |...11112222.....|
I (103543) RECV BLE DATA: 0x3f815fa0   ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
I (103553) RECV BLE DATA: 0x3f815fb0   ff 53                                             |.S|
W (103563) RUN_MODE1: [BLE] BleHead1 : 1, packet size: 66
W (103573) RUN_MODE1: [BLE] BleHead2 : 1 msg.data_len: 66, msg.checksum: 83, cal.checksum: 83
I (103583) COPY BLE DATA: 0x3ffc4838   24 41 44 06 42 4c 75 69  73 49 70 68 6f 6e 65 ff  |$AD.BLuisIphone.|
I (103593) COPY BLE DATA: 0x3ffc4848   ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
I (103603) COPY BLE DATA: 0x3ffc4858   ff ff ff 31 31 31 31 32  32 32 32 ff ff ff ff ff  |...11112222.....|
I (103613) COPY BLE DATA: 0x3ffc4868   ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
I (103623) COPY BLE DATA: 0x3ffc4878   ff 53                                             |.S|
W (103633) RUN_MODE1: [BLE] Data : $ADBLuisIphoneÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ11112222ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿS
W (103643) RUN_MODE1: [BLE] Run process, 0x6
E (103643) RUN_MODE1: Start WIFI connection
I (103653) APP_MAIN: BLE_TRANS_WIFI_CONN_SSID_FULL
I (103653) APP_MAIN: SSID:LuisIphone PASSWORD:11112222
I (103663) APP_MAIN: Delete wifi previous infomation
I (103743) APP_MAIN: bf_file write
W (103763) RUN_MODE1: [BLE] BleHead3 : 1
W (103763) RUN_MODE1: [BLE] BleHead4 : 2
I (103963) BF_SDCARD*: Read from sd: '8aU_5\T[ZQ
I (103963) BF_SDCARD*: Read from sd: ''
I (103963) APP_MAIN: [BleWifiConnTask]SSID:LuisIphone PASSWORD:11112222
I (103973) BF_WIFI*: esp_netif_init
W (103973) esp_netif_lwip: esp-netif has been successfully initialized
I (103983) BF_WIFI*: esp_event_loop_create_default
W (103983) event: created task for loop 0x3ffe3e34
W (103993) event: created event loop 0x3ffe3e34
I (103993) BF_WIFI*: esp_netif_create_default_wifi_sta
I (104003) BF_WIFI*: wifi_init_config_t
I (104003) BF_WIFI*: esp_wifi_init
I (104023) wifi:wifi driver task: 3ffe3650, prio:23, stack:6656, core=0
I (104033) wifi:wifi firmware version: eb52264
I (104033) wifi:wifi certification version: v7.0
I (104033) wifi:config NVS flash: enabled
I (104033) wifi:config nano formating: disabled
I (104033) wifi:Init data frame dynamic rx buffer num: 32
I (104043) wifi:Init management frame dynamic rx buffer num: 32
I (104053) wifi:Init management short buffer num: 32
I (104053) wifi:Init static tx buffer num: 16
I (104053) wifi:Init tx cache buffer num: 32
I (104063) wifi:Init static rx buffer size: 1600
I (104063) wifi:Init static rx buffer num: 10
I (104073) wifi:Init dynamic rx buffer num: 32
I (104073) wifi_init: rx ba win: 16
I (104073) wifi_init: tcpip mbox: 32
I (104083) wifi_init: udp mbox: 6
I (104083) wifi_init: tcp mbox: 6
I (104093) wifi_init: tcp tx win: 5744
I (104093) wifi_init: tcp rx win: 5744
I (104103) wifi_init: tcp mss: 1436
I (104103) wifi_init: WiFi/LWIP prefer SPIRAM
I (104113) BF_WIFI*: esp_wifi_set_mode result: 0
I (104133) BF_WIFI*: esp_wifi_set_config result: 0
I (104133) wifi:mode : sta (c4:dd:57:6a:a0:0c)
I (104133) wifi:enable tsf
I (104133) BF_WIFI*: esp_wifi_start result: 0
I (104133) BF_WIFI*: Start wifi connect
I (104153) wifi:new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
I (104153) wifi:state: init -> auth (b0)
I (104153) wifi:state: auth -> assoc (0)
I (104163) wifi:state: assoc -> run (10)
I (104233) wifi:connected with LuisIphone, aid = 1, channel 6, BW20, bssid = 0e:e5:f9:df:6b:31
I (104233) wifi:security: WPA2-PSK, phy: bgn, rssi: -33
I (104243) wifi:pm start, type: 1
I (104253) wifi:AP's beacon interval = 102400 us, DTIM period = 1
W (104303) wifi:<ba-add>idx:0 (ifx:0, 0e:e5:f9:df:6b:31), tid:0, ssn:2, winSize:64
I (105253) esp_netif_handlers: sta ip: 172.20.10.2, mask: 255.255.255.240, gw: 172.20.10.1
I (105253) BF_WIFI*: got ip:172.20.10.2
I (105253) BF_WIFI*: WI-FI connect bit result: 0x1
I (105253) BF_WIFI*: connected to ap SSID:LuisIphone password:11112222
W (105263) APP_MAIN: [BleWifiConnTask]Success to connect WIFI
I (105273) APP_MAIN: WIFI_Total_SendJson
W (105273) HTTP_CLIENT: max_redirection_count 50
I (105283) APP_MAIN: [WIFI_Total_Http_Send]success to esp_http_client_init
W (105293) HTTP_CLIENT: set post file length = 36
W (105293) HTTP_CLIENT: Begin connect to: https://log.bodyfriend.co.kr:443
W (105303) esp-tls: host:log.bodyfriend.co.kr: strlen 20
W (105313) esp-tls: addrinfo->ai_family == AF_INET
W (105313) esp-tls: [sock=-1] Resolved IPv4 address: 192.168.1.72
W (105323) esp-tls: [esp_tcp_connect]fd 54 addrinfo->ai_addrlen 28
W (105333) esp-tls: connecting...
W (114653) esp-tls: handshake in progress...
E (114653) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x4e, 0xffffffb2
I (114653) esp-tls-mbedtls: Certificate verified.
E (114653) HTTP_CLIENT: Connection failed
E (114663) APP_MAIN: Error perform http request ESP_ERR_HTTP_CONNECT
I (114673) BF_WIFI*: bf_wifi_connect.c
I (114683) APP_MAIN: Fail to send testdata
E (114683) APP_MAIN: [BleWifiConnTask]Fail to send data to server
I (114693) wifi:state: run -> init (0)
I (114693) wifi:pm stop, total sleep time: 8071399 us / 10453347 us
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 223 guests
