<SOLVED> IDF esp_wifi_stop() interfering with LEDC operation
felixcollins
Postby felixcollins » Mon Jan 30, 2023 4:03 am
Hi, I've got a weird problem whereby when I turn wifi off (not that this is off not on) my leds under control of ledc start flickering. When I re-enable wifi they go back to normal. I suspect this is something to do with the wifi turn off code doing something to the clock supplying the ledc module but I really have no clue. My wifi stop code is below. Some of if it non-idf obviously.
Does anyone have any ideas as to where to start looking?
void wifi_stop()
	telemetry_notify_wifi_disconnected();
	webserver_stop();
	AP_state = AP_STATE_Off;
	STA_state = STA_STATE_Idle;
	deinit_mini_dns();
	esp_netif_deinit();
	esp_wifi_stop();
	if (reconnect_timer)
		xTimerStop(reconnect_timer, (TickType_t)1000 / portTICK_PERIOD_MS);
		xTimerReset(reconnect_timer, 1);
	if (ap_stop_timer)
		xTimerStop(ap_stop_timer, (TickType_t)1000 / portTICK_PERIOD_MS);
		xTimerReset(ap_stop_timer, 1);
	wifi_state = WIFI_STATE_STOPPED;
	led_change_pattern(LED_WIFI_OFF, true);
felixcollins
Re: IDF esp_wifi_stop() interfering with LEDC operation
Postby felixcollins » Mon Jan 30, 2023 8:23 pm
I've narrowed down the source of the issue to the esp_wifi_stop() function. If all I do is call that function it causes my LEDC controlled leds to start flickering erratically. Unfortunately esp_wifi_stop() is bundled as a library so there is no source code to see where the issue is. Could an Espressif person with access to the code please take a look? Perhaps I should just log a bug.
felixcollins
Postby felixcollins » Mon Jan 30, 2023 8:59 pm
Just in case it matters... I'm running on a WROOM32E. Custom board.
	ledc_timer_config_t ledc_timer =
		.duty_resolution = LEDC_TIMER_13_BIT,
		.freq_hz = 5000,
		.speed_mode = LEDC_HIGH_SPEED_MODE,
		.timer_num = LEDC_TIMER_0,
		.clk_cfg = LEDC_USE_APB_CLK,
	ledc_timer_config(&ledc_timer);
LEDS on channels 0,1,2,3,4. GPIOs 26,25,27,2,4
All on High Speed Mode.
felixcollins
Postby felixcollins » Mon Jan 30, 2023 10:55 pm
This does seem to be a bug. I worked around it by changing the clock source for the LEDC module. LEDC_USE_RTC8M_CLK is not used by wifi.
		.duty_resolution = LED_PWM_RESOLUTION_SELECTED,
		.freq_hz = LED_PWM_FREQ_SELECTED,
		.speed_mode = LED_SPEED_MODE_SELECTED,
		.timer_num = LED_TIMER_SELECTED,
		.clk_cfg = LEDC_USE_RTC8M_CLK,
	ESP_ERROR_CHECK(ledc_timer_config(&ledc_timer));
felixcollins
Re: <SOLVED> IDF esp_wifi_stop() interfering with LEDC operation
Postby felixcollins » Thu Feb 02, 2023 12:36 am
Light sleep must also be disabled.
Users browsing this forum: No registered users and 230 guests
