I'm kinda running out of pins with my WT32-SC01. The SPI bus is shared between the SD card and the LCD. I'd like to share the CS pin as well.
Is it possible to setup esp_vfs_fat_sdspi_mount with the CS inverted logic? I'll probably need to add an external logic inverter before the SD card CS pin to restore the inverted signal.
SD SPI CS pin inverted logic possible?
Re: SD SPI CS pin inverted logic possible?
I don't know what kind of LCD driver you're using. It seems that with the IDF's esp_lcd component you can try and set the cs_high_active flag in esp_lcd_panel_io_spi_config_t.
The SDSPI seems to manage CS by software, so you could modify sdspi_host.c and disable or swap the calls to cs_low(slot) and cs_high(slot).
In theory, this kind of multiplexing of CS should work. You'll have to test if it actually does though because there may be some "dummy" data/clocks sent before or after some SPI transactions while /CS is supposed to be high, which instead of being ignored would then be seen as garbage data by the respective other SPI slave.
Users browsing this forum: No registered users and 240 guests
