How to use gpio_isr_register?
Re: How to use gpio_isr_register?
Postby rudi ;-) » Sat Oct 22, 2016 4:54 pm
mhm..
gpios i want use, 17 and 18..
#define PIR_GPIO 17
#define BTN_GPIO 18
select gpios..
gpio_pad_select_gpio(PIR_GPIO);
gpio_pad_select_gpio(BTN_GPIO);
set direction..
/* Set the GPIO as a input */
gpio_set_direction(PIR_GPIO, GPIO_MODE_INPUT);
gpio_set_direction(BTN_GPIO, GPIO_MODE_INPUT);
set pulls..
/* Set the GPIO pull */
gpio_set_pull_mode(PIR_GPIO, GPIO_PULLUP_ONLY);
gpio_set_pull_mode(BTN_GPIO, GPIO_PULLUP_ONLY);
set intr type for each
gpio_set_intr_type(PIR_GPIO, GPIO_INTR_ANYEDGE);
gpio_set_intr_type(BTN_GPIO, GPIO_INTR_NEGEDGE);
ok i think top is ok...
..now..
enable for each..
( ...but i think this goes wrong...)
gpio_intr_enable(PIR_GPIO);
gpio_intr_enable(BTN_GPIO);
must be..
gpio_intr_enable(DUMMY);
register isr
( ...but think we need only one..)
// Intterrupt number see below
 gpio_isr_register(PIR_GPIO, gpioCallback, (void *)TAG); // 17
 gpio_isr_register(BTN_GPIO, gpioCallback, (void *)TAG); // 18
must be...
 gpio_isr_register(DUMMY, gpioCallback, (void *)TAG);  // not specified
and in isr we select then by
uint32_t gpio_intr_status = READ_PERI_REG(GPIO_STATUS_REG);   //read status to get interrupt status for GPIO0-31
uint32_t gpio_intr_status_h = READ_PERI_REG(GPIO_STATUS1_REG);//read status1 to get interrupt status for GPIO32-39
..let me try again ... i think i have understand...
Postby rudi ;-) » Sat Oct 22, 2016 5:20 pm
mhm..
1 Intr GPIO17 ,val: 0<\r><\n>
GPIO 17 request<\r><\n>
1 Intr GPIO17 ,val: 1<\r><\n>
1 Intr GPIO18 ,val: 1<\r><\n>
GPIO 18 request : restart call<\r><\n>
if gpio17 fired, and if was gpio18 fired too, then gpio18 is named.
..ok..let me work further...
Postby rudi ;-) » Sat Oct 22, 2016 5:28 pm
WiFive wrote:
gpio_isr_register(INPUT_GPIO, gpioCallback, (void *)TAG); // 17
By coincidence, INPUT_GPIO = 17 so it works.
ah...
*      22                      3               extern edge
*      28                      4               extern edge
*      29                      3               software                Reserved                Reserved
*      30                      4               extern edge             Reserved                Reserved
we can register isr for edge ( falling, rising, any ) on "TAG" 22, 28 and 30 is reserved.
and over gpio_num we can get _ which gpio was fired if set as inputs ? ..
right?...
.. mhm..
Postby rudi ;-) » Sat Oct 22, 2016 6:32 pm
No WiFive
there must be other reason for panic'ed:
void app_main()
  nvs_flash_init();
  system_init();
  // xTaskCreate(&main_task, "main_task", 2048, NULL, 5, NULL);
  system_restart();
ets Jun  8 2016 00:22:57<\r><\n>
<\r><\n>
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)<\r><\n>
<\r><\n>
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)<\r><\n>
configsip: 0, SPIWP:0x00<\r><\n>
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00<\r><\n>
mode:QIO, clock div:2<\r><\n>
load:0x3ffc0000,len:0<\r><\n>
load:0x3ffc0000,len:920<\r><\n>
load:0x40078000,len:2724<\r><\n>
ho 0 tail 12 room 4<\r><\n>
load:0x40098000,len:508<\r><\n>
entry 0x40098118<\r><\n>
<27>[0;32mI (70) heap_alloc_caps: Initializing heap allocator:<27>[0m<\r><\n>
<27>[0;32mI (71) heap_alloc_caps: Region 19: 3FFB4240 len 0002BDC0 tag 0<27>[0m<\r><\n>
<27>[0;32mI (72) heap_alloc_caps: Region 25: 3FFE8000 len 00018000 tag 1<27>[0m<\r><\n>
<27>[0;32mI (82) cpu_start: Pro cpu up.<27>[0m<\r><\n>
<27>[0;32mI (87) cpu_start: Starting app cpu, entry point is 0x40080948<27>[0m<\r><\n>
<27>[0;32mI (0) cpu_start: App cpu up.<27>[0m<\r><\n>
<27>[0;32mI (102) cpu_start: Pro cpu start user code<27>[0m<\r><\n>
rtc v112 Sep 26 2016 22:32:10<\r><\n>
XTAL 40M<\r><\n>
<27>[0;32mI (138) cpu_start: Starting scheduler on PRO CPU.<27>[0m<\r><\n>
<27>[0;32mI (42) cpu_start: Starting scheduler on APP CPU.<27>[0m<\r><\n>
frc2_timer_task_hdl:3ffb9684, prio:22, stack:2048<\r><\n>
c:/sdk32/esp-idf/components/freertos/./queue.c:603 (xQueueGenericSend)- assert failed!<\r><\n>
Guru Meditation Error: Core   0 panic'ed.<\r><\n>
Register dump:<\r><\n>
PC      : Guru Meditation Error of type LoadProhibited occurred on core   0. Exception was unhandled.<\r><\n>
PC      :  40083456  PS      :  00060033  A0      :  80083679  A1      :  3ffb5e70  <\r><\n>
A2      :  00000000  A3      :  00000002  A4      :  00000000  A5      :  00000000  <\r><\n>
A6      :  3f401044  A7      :  3ff4001c  A8      :  0000007d  A9      :  3ff4001c  <\r><\n>
A10     :  3ff4001c  A11     :  3f4002d0  A12     :  00000000  A13     :  3ffb5ed0  <\r><\n>
A14     :  00000000  A15     :  3f401158  SAR     :  00000019  EXCCAUSE:  0000001c  <\r><\n>
EXCVADDR:  00000004  LBEG    :  4000c2e0  LEND    :  4000c2f6  LCOUNT  :  00000000  <\r><\n>
Rebooting...<\r><\n>
<\r><\n>
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)<\r><\n>
<27>[0;32mI (324) heap_alloc_caps: Initializing heap allocator:<27>[0m<\r><\n>
<27>[0;32mI (325) heap_alloc_caps: Region 19: 3FFB4240 len 0002BDC0 tag 0<27>[0m<\r><\n>
<27>[0;32mI (335) heap_alloc_caps: Region 25: 3FFE8000 len 00018000 tag 1<27>[0m<\r><\n>
<27>[0;32mI (395) cpu_start: Pro cpu up.<27>[0m<\r><\n>
<27>[0;32mI (430) cpu_start: Starting app cpu, entry point is 0x40080948<27>[0m<\r><\n>
<27>[0;32mI (523) cpu_start: Pro cpu start user code<27>[0m<\r><\n>
XTAL 40M<\r><\n>
<27>[0;32mI (702) cpu_start: Starting scheduler on PRO CPU.<27>[0m<\r><\n>
<27>[0;32mI (213) cpu_start: Starting scheduler on APP CPU.<27>[0m
Postby rudi ;-) » Sat Oct 22, 2016 6:57 pm
my change now:
// set gpios
#define PIR_GPIO 17
#define BTN_GPIO 18
// change..
// Interrupt Number 22  // edit
// taken for extern edge from table
#define INT_NUMB 22 // edit
#define TAG 3
select each gpio..
direction each gpio..
pull each gpio..
intr type for each gpio...
i set here for each gpio enable the the isr
and this runs for me.
not sure that we "must" set only onetime
but this runs for me here:
enable intr each gpio..
and here is my change...
only one registered isr callback for the "INTR_Numb 22"
i am sure we can set a second if we create a new with second INTR_NUMB like table.
register INTR_NUMB callback for ..
gpio_isr_register(INT_NUMB, gpioCallback, (void *)TAG);
runs for me like i need...
1 Intr GPIO18 ,val: 0<\r><\n>
GPIO 18 request<\r><\n>
any objection?
this
system_restart();
generates this panic*ed :
try a simple app code and make a system_restart();
here my code:
 * Espressif IoT Development Framework with the ESP32
 * ESP-IDF -
 * the new Espressif IoT Development Framework with ESP32 from espressif
 * github              : https://github.com/espressif/esp-idf
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "driver/gpio.h"
#define PIR_GPIO 17
#define BTN_GPIO 18
#define TAG 3
void gpioCallback (void* arg);
 * FunctionName : main_task
 * Description  :
 * Parameters   : void* pvParameter
 * Returns      : void
void main_task(void* pvParameter)
  /* Configure the IOMUX register for pad BLINK_GPIO (some pads are
         muxed to GPIO on reset already, but some default to other
         functions and need to be switched to GPIO. Consult the
         Technical Reference for a list of pads and their default
         functions.)
      // gpio_set_intr_type(INPUT_GPIO, GPIO_INTR_NEGEDGE);
      while(1) {
      //   printf( "Loop...\n" );
      //  vTaskDelay(1000 / portTICK_RATE_MS);
 * FunctionName : gpioCallback
 * Description  :
 * Parameters   : void* arg
 * Returns      :
void gpioCallback(void* arg)
    uint32_t gpio_num = 0;
    SET_PERI_REG_MASK(GPIO_STATUS_W1TC_REG, gpio_intr_status);    //Clear intr for gpio0-gpio31
    SET_PERI_REG_MASK(GPIO_STATUS1_W1TC_REG, gpio_intr_status_h); //Clear intr for gpio32-39
    do {
      if(gpio_num < 32) {
        if(gpio_intr_status & BIT(gpio_num)) { //gpio0-gpio31
		ets_printf("1 Intr GPIO%d ,val: %d\n",gpio_num,gpio_get_level(gpio_num));
           //This is an isr handler, you should post an event to process it in RTOS queue.
		   switch (gpio_num) {
			   case 17: ets_printf("GPIO 17 request\n"); break;
			   case 18: ets_printf("GPIO 18 request\n");
			            // fflush(stdout);
						// system_restart();
        if(gpio_intr_status_h & BIT(gpio_num - 32)) {
          ets_printf("2 Intr GPIO%d, val : %d\n",gpio_num,gpio_get_level(gpio_num));
  } while(++gpio_num < GPIO_PIN_COUNT);
  /* push_status = ; */
 * * * * * * * *: main of ESP32
 * FunctionName : app_main
 * Description  : entry of user application, init user function here
 * Parameters   : none
 * Returns      : none
void app_main()
  nvs_flash_init();
  system_init();
Postby rudi ;-) » Sat Oct 22, 2016 7:06 pm
WiFive wrote:
Also don't do this:
2nd one cancels the first one and you fell into jimbob's trap
honest - i am not sure in this point -
perhabs one of the esp guys can talk the right way on this.
my code runs like i need with this setup.
ok i have change the callback now,
there you was right, i take the INTR_Numb 22 for extern edge for this now. // edit ( 23 is my com sry )
Postby rudi ;-) » Sat Oct 22, 2016 7:13 pm
WiFive wrote:No no. You do this many times:
gpio_intr_enable(GPIO_NUM)
how must this then enable for each?
GPIO_NUM was not the right parameter
i changed this to INTR_NUMB from table for "one INTR Resource"
And you do this only ONCE:
gpio_isr_register(UNUSED_INTERRUPT_NUM, gpioCallback, (void *)TAG);
you mean, i must create for each enabled intr on gpio ( edge ) a new callback register?
is this possible or is this a must?
And then you do this inside gpioCallback:
do {
Capisce? 8-)
i am honest not sure, that you Capisce the lines
means - is the intr bit was set for the gpio_num...that comes in..
and this?..
counts the gpios in the isr
and yes - this i do in the isr,
because if set outside from isr
i delay the isr and this is not good for the isr.
Capisce? 8-)
the question is ...
@ESP_Sprite..
why system_restart(); makes panic'ed
this is more important.
Postby rudi ;-) » Sat Oct 22, 2016 9:17 pm
No,
my code is not right :(
there is a small mistake in it..
if i set one gpio(gpio18) enable for isr i get for the other ( gpio17 ) no fired isr, this is right,
but in the
example gpio18 fired then i get for gpio_intr_status
262144 ( uint32_t)
means
1000000000000000000
gpio18
if i push gpio17 i get no fired isr,
but if i push gpio18,
i get gpio_intr_status
393216
means
1100000000000000000
gpio18 + gpio17
do we have no document on ISR / INTR / Gpio just in time?
thanks
i know, I2C slave on esp8266 with sda and scl intr was not light but was done..
but we have here in esp32 2 cores and more resource and i think 76 possible peripherial INTR...
so perhabs we wait better for the document?
:roll:
Postby rudi ;-) » Sat Oct 22, 2016 9:28 pm
:lol:
this theme is just in time from me in monolog sry ;-)
ok.
because i set only one for enable,
there is no clear on the mask for the pushed?
right?
then we have a chance that my code is right?...
now i setup all too for enable and ...
i get for gpio17
131072
means
100000000000000000
and for gpio18
262144
means
1000000000000000000
GPIO 17 pushed<\r><\n>
handler : 131072<\r><\n>
GPIO 18 pushed<\r><\n>
handler : 262144<\r><\n>
 * Description  :
 * Returns      :
    do {
      if(gpio_num < 32) {
		   switch (gpio_num) {
			   case 17: ets_printf("GPIO 17 pushed\n");
						ets_printf("handler : %lu\n", gpio_intr_status);
			   case 18: ets_printf("GPIO 18 pushed\n");
						// fflush(stdout);
WiFive
Postby WiFive » Sat Oct 22, 2016 11:27 pm
Well I guess if you system_restart from CPU1 you cause exception on CPU0. Not a graceful restart.
Users browsing this forum: jsam589 and 16 guests
