Is there a way to provision the ESP32 when first configuring Rainmaker, to use a Static IP?
This is very important for me.
Thanks!
How to configure the Rainmaker ESP32 to use a static IP?
Re: How to configure the Rainmaker ESP32 to use a static IP?
Moved this topic under ESP IDF since RainMaker uses ESP IDF's wifi provisioning. As of now, it can accept only ssid, passphrase, bssid and channel. There is no provision to set static IP.
Hi, can you provide the link to the other forum so that I can follow the discusson there? Thanks!
Users browsing this forum: No registered users and 125 guests
