IPC Crash
felixcollins
IPC Crash
Postby felixcollins » Tue Oct 17, 2023 3:41 am
I had a crash randomly. I'm running with JTAG attached using vscode.
Anyone care to comment? Was this a glitch? Should I be worried?
The image will expire in three months.
The key points are the code (crashed at the l32i instruction):
esp_ipc_isr_waiting_for_finish_cmd:
    /* waiting for the finish command */
.check_finish_cmd:
    memw
    l32i    a3, a2, 0
    beqz    a3, .check_finish_cmd
    ret
and the register values:
a3 = 0
a2 = 1073436660
Call stack:
esp_ipc_isr_waiting_for_finish_cmd (c:\Users\felix\esp\esp-adf\esp-adf\esp-idf\components\esp_ipc\src\esp_ipc_isr\esp_ipc_isr_routines.S:27)
0x80107fe8 ()
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS win32 x64 10.0.19045
System environment variable IDF_PYTHON_ENV_PATH
undefined
System environment variable PATH (CLIPPED for Privacy)
System environment variable PYTHON
undefined
Visual Studio Code version 1.83.0
Visual Studio Code language en
Visual Studio Code shell C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe
ESP-IDF Extension version 1.6.5
Workspace folder c:<HOMEPATH>\source\beakbox\Firmware\beakbox3
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) C:<HOMEPATH>\.espressif\esp-adf
ESP-IDF Path (idf.espIdfPath) c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
ESP-Matter Path (idf.espMatterPath) ${env:ESP_MATTER_PATH}
Custom extra paths (idf.customExtraPaths) c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp-elf-gdb\11.2_20220823\xtensa-esp-elf-gdb\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf-gdb\11.2_20220823\riscv32-esp-elf-gdb\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32-elf\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s2-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s2-elf\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s3-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\cmake\3.23.1\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\openocd-esp32\v0.11.0-esp32-20221026\openocd-esp32\bin;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ninja\1.10.2;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\idf-exe\1.0.3;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ccache\4.3\ccache-4.3-windows-64;c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\dfu-util\0.9\dfu-util-0.9-win64
Custom extra vars (idf.customExtraVars)
OPENOCD_SCRIPTS: c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\openocd-esp32\v0.11.0-esp32-20221026\openocd-esp32\share\openocd\scripts
IDF_CCACHE_ENABLE: 1
Virtual env Python Path (idf.pythonBinPath) c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\python_env\idf4.4_py3.8_env\Scripts\python.exe
Serial port (idf.port) COM6
OpenOCD Configs (idf.openOcdConfigs) interface/ftdi/tumpa-lite.cfg,target/esp32.cfg
ESP-IDF Tools Path (idf.toolsPath) c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools
Git Path (idf.gitPath) c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\idf-git\2.30.1\cmd\git.exe
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espAdfPath) true
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espMdfPath) false
Access to ESP-Matter Path (idf.espMatterPath) false
Access to ESP-IDF Custom extra paths
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp-elf-gdb\11.2_20220823\xtensa-esp-elf-gdb\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf-gdb\11.2_20220823\riscv32-esp-elf-gdb\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32-elf\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s2-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s2-elf\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s3-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\cmake\3.23.1\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\openocd-esp32\v0.11.0-esp32-20221026\openocd-esp32\bin: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ninja\1.10.2: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\idf-exe\1.0.3: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ccache\4.3\ccache-4.3-windows-64: true
Access to c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\dfu-util\0.9\dfu-util-0.9-win64: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH undefined
Access to Ninja in environment PATH undefined
Access to ESP-IDF Tools Path (idf.toolsPath) true
-------------------------------------------------------- Configurations has spaces -------------------------------------------------------------
Spaces in system environment Path true
Spaces in ESP-ADF Path (idf.espAdfPath) false
Spaces in ESP-IDF Path (idf.espIdfPath) false
Spaces in ESP-MDF Path (idf.espMdfPath) false
Spaces in ESP-Matter Path (idf.espMatterPath) false
Spaces in ESP-IDF Custom extra paths
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp-elf-gdb\11.2_20220823\xtensa-esp-elf-gdb\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf-gdb\11.2_20220823\riscv32-esp-elf-gdb\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32-elf\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s2-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s2-elf\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\xtensa-esp32s3-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\riscv32-esp-elf\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\cmake\3.23.1\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\openocd-esp32\v0.11.0-esp32-20221026\openocd-esp32\bin: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ninja\1.10.2: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\idf-exe\1.0.3: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\ccache\4.3\ccache-4.3-windows-64: false
Spaces in c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\tools\tools\dfu-util\0.9\dfu-util-0.9-win64: false
Spaces in Virtual env Python Path (idf.pythonBinPath) false
Spaces in ESP-IDF Tools Path (idf.toolsPath) false
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.30.1.windows.1
ESP-IDF version 4.4.5
Python version 3.8.7
Python's pip version 21.2.3
-------------------------------------------------- Project configuration settings ----------------------------------------------------------
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
bitstring version: 3.1.9
Brotli version: 1.0.9
CacheControl version: 0.13.0
certifi version: 2023.5.7
cffi version: 1.15.1
charset-normalizer version: 3.1.0
click version: 8.0.4
colorama version: 0.4.6
construct version: 2.10.54
contextlib2 version: 21.6.0
cryptography version: 41.0.1
ecdsa version: 0.18.0
esp-debug-backend version: 1.0.3
esp-windows-curses version: 0.1
filelock version: 3.12.0
Flask version: 0.12.5
Flask-Compress version: 1.13
Flask-SocketIO version: 2.9.6
future version: 0.18.2
gcovr version: 6.0
gdbgui version: 0.13.2.0
gevent version: 1.5.0
greenlet version: 2.0.2
idf-component-manager version: 1.4.0
idna version: 3.4
itsdangerous version: 2.0.1
Jinja2 version: 3.0.3
kconfiglib version: 13.7.1
lxml version: 4.9.2
MarkupSafe version: 2.1.3
msgpack version: 1.0.5
packaging version: 23.1
pip version: 21.2.3
psutil version: 5.9.5
pycparser version: 2.21
pyelftools version: 0.29
pygdbmi version: 0.9.0.2
Pygments version: 2.15.1
pyparsing version: 2.2.0
pyserial version: 3.5
python-engineio version: 3.14.2
python-socketio version: 4.6.1
pywin32 version: 306
PyYAML version: 6.0
reedsolo version: 1.5.4
requests version: 2.31.0
requests-file version: 1.5.1
requests-toolbelt version: 1.0.0
schema version: 0.7.5
setuptools version: 68.2.2
six version: 1.16.0
tqdm version: 4.65.0
urllib3 version: 1.26.16
websocket-client version: 1.6.3
Werkzeug version: 0.16.1
wheel version: 0.36.2
windows-curses version: 2.3.1
xmlrunner version: 1.7.7
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages Python requirements from c:<HOMEPATH>\esp\esp-adf\esp-adf\esp-idf\requirements.txt are satisfied.
---------------------------------------------------- Check extension requirements.txt ------------------------------------------------------
Check Extension Python packages Python requirements from c:<HOMEPATH>\.vscode\extensions\espressif.esp-idf-extension-1.6.5\requirements.txt are satisfied.
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages Python requirements from c:<HOMEPATH>\.vscode\extensions\espressif.esp-idf-extension-1.6.5\esp_debug_adapter\requirements.txt are satisfied.
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "DefaultIDF",
"request": "launch",
"logLevel": 5,
"type": "espidf",
"name": "IDF",
"debugPort": 43474,
"logLevel": 5,
"mode": "auto",
"verifyAppBinBeforeDebug": false,
"tmoScaleFactor": 2,
"initGdbCommands": [
"target remote :3333",
"set remote hardware-watchpoint-limit 2",
"symbol-file build/beakbox3.elf",
"mon reset halt",
"flushregs",
"thb app_main"
"env": {
"CUSTOM_ENV_VAR": "SOME_VALUE"
"name": "CPPDBG",
"type": "cppdbg",
"program": "C:\\Users\\felix\\source\\beakbox\\Firmware\\beakbox3\\build\\beakbox3.elf",
"args": [],
"stopAtEntry": true,
"cwd": "${workspaceFolder}",
"environment": [],
"externalConsole": false,
"MIMode": "gdb",
"miDebuggerPath": "${command:espIdf.getXtensaGdb}",
"setupCommands": [
"description": "Enable pretty-printing for gdb",
"text": "-enable-pretty-printing",
"ignoreFailures": true
"text": "target remote localhost:3333"
"text": "monitor reset halt"
"text": "flushregs"
"text": "thb app_main"
"logging": {
"trace": true,
"traceResponse": true,
"engineLogging": true
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
"configurations": [
"name": "ESP ADF",
"includePath": [
"${workspaceFolder}/**",
"C:/Users/felix/esp/esp-adf/**",
"C:/Users/felix/esp/esp-adf/esp-adf/esp-idf/components/**"
"defines": [
"_DEBUG",
"UNICODE",
"_UNICODE"
"compilerPath": "C:\\Users\\felix\\esp\\esp-adf\\esp-adf\\esp-idf\\tools\\tools\\xtensa-esp32-elf\\esp-2021r2-patch5-8.4.0\\xtensa-esp32-elf\\bin\\xtensa-esp32-elf-gcc-8.4.0.exe",
"cStandard": "c17",
"cppStandard": "c++17",
"intelliSenseMode": "gcc-arm"
"version": 4
Users browsing this forum: Bing [Bot], ESP_Sprite and 199 guests
