esp_sleep_enable_ext0_wakeup not working
pablopabota
Postby pablopabota » Wed Oct 25, 2023 5:16 am
I'm trying to wake up my ESP-32 WROVER-E from an external source using the esp_sleep_enable_ext0_wakeup() function:
void go_to_sleep(uint32_t useconds)
	esp_wifi_stop();
	esp_sleep_enable_ext0_wakeup(GPIO_NUM_4, 0);
	esp_deep_sleep(useconds);
I call that function in order to send my device to sleep, but as soon as it "power down" it wakes up immediately, I tried wake up on "high" level and "low" yet the same behaviour.
I tried the power domain function, the pull ups and down and nothing worked.
If I comment the wakeup source line the device go to sleep the time setted, and the GPIO 4 stays "high" for the whole sleeping period.
esp_sleep_get_wakeup_cause() returns ESP_SLEEP_WAKEUP_EXT0 and GPIO_NUM_4 is the only setted wake up source.
Did I missed something? Any idea?
Regards,
P
PS:
1) I run 'rtc_deinit' the GPIO pin when device wakes up.
2) I'm using ESP-IDF 4.4.5
3) Chip is ESP32-D0WD-V3 (revision v3.0)
chegewara
Re: esp_sleep_enable_ext0_wakeup not working
Postby chegewara » Tue Mar 19, 2024 4:35 pm
        esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_ON);
        esp_sleep_enable_ext0_wakeup((gpio_num_t)BUTTON_PIN, 0);
        esp_deep_sleep_start();
Users browsing this forum: hdsjulian2 and 221 guests
