Hi All,
Finally I got a static IP for Ethernet, modifying the function tcpip_adapter_dhcpc_stop, but when I test the SNTP example, is not possible to get the time from the server.
This behavior is normal or I missing something?
Regards
Thanks in advance.
Juan
Ethernet with IP static and SNTP
Re: Ethernet with IP static and SNTP
Static IP you need to provide DNS server address
(Not a hardware question, wrong forum)
Moved to SDK forum.
Hi All,
Thanks for the tip about DNS
Sorry to habe bben in the HDK
Regards
Juan
Have a nice WE
Regards
Juan
Have a nice WE
Hi WiFive,WiFive wrote:Static IP you need to provide DNS server address
It is a question again about Static IP and DNS..., the situation is as you mention is necessary to provide de DNS server address, so far is Ok and I have tested it, but my new question it is a issue inside the LWIP and/or the ESP32?... or better why with static IP the DNS is not resolved and we have to use the address?
Thanks in advance
Juan
DNS addresses are obtained with DHCP when using dynamic ip. When using static IP you need to provide it yourself. If you've ever configured the network address on a PC you'd see the same thing.
John A
John A
Users browsing this forum: No registered users and 67 guests
