Wifi: Changing Hostname
tim-hilt
Postby tim-hilt » Thu Mar 21, 2024 9:57 pm
I tried adapting the wifi-station-example (https://github.com/espressif/esp-idf/bl ... ple_main.c), so that the hostname is changed via
esp_netif_set_hostname
More specifically, I changed this line from the example:
esp_netif_create_default_wifi_sta();
to this:
esp_netif_t* netif = esp_netif_create_default_wifi_sta();
  ESP_ERROR_CHECK(esp_netif_set_hostname(
      netif, "something"));
The code compiles and runs just fine, however the hostname is still showns as "espressif" when looking at my home-network.
How do I have to change the wifi-station-example, so that the hostname is adapted?
chegewara
Re: Wifi: Changing Hostname
Postby chegewara » Fri Mar 22, 2024 12:53 am
Did you try to start wifi before _set_hostname?
tim-hilt
Postby tim-hilt » Fri Mar 22, 2024 7:31 am
Thanks for your reply! I moved the _set_hostname call after
ESP_ERROR_CHECK(esp_wifi_start() );
, but unfortunately the hostname still isn't changed.
Do I have to change the hostname after wifi is connected maybe? Or as soon as there is an IP address assigned?
chegewara
Postby chegewara » Mon Mar 25, 2024 7:13 pm
To be honest i dont know what is the correct order, because i am using half-automated library for this, but i have some weird observation.
It is working on some routers and on the other routers it shows old "espressif" hostname.
Im guessing that the 2nd case, when it shows "espressif" hostname is not updating it and remember first hostname associated with esp32 MAC.
Works on huawei HG8245Q2, is not working on TP-link deco M4, with exactly the same code.
PS after short time even tp-link deco is updating esp32 according to hostname set in the code
Users browsing this forum: No registered users and 211 guests
