I2C latency
Jstar88
I2C latency
Postby Jstar88 » Fri Feb 16, 2018 6:24 pm
i'm using I2C in master mode(ESP32) to communicate with a single slave(LCD).
The SDK is the last one at this date.
I'm having some troubles with performance since commands are delayed each other by over 100us.
You can see the follow screenshots
http://www.image-share.com/ipng-3693-170.html
#define LCD_SCL_PIN GPIO_NUM_5
#define LCD_SDA_PIN GPIO_NUM_18
bool Display_writeComIIC(Display* obj, int para)
	bool status = false;
	i2c_cmd_handle_t cmd = i2c_cmd_link_create();
	i2c_master_start(cmd);
	i2c_master_write_byte(cmd, (obj->address << 1) | I2C_MASTER_WRITE, true);
	i2c_master_write_byte(cmd, 0x20, true);
	i2c_master_write_byte(cmd, para, true);
	i2c_master_stop(cmd);
	if (i2c_master_cmd_begin(I2C_NUM_0, cmd, 1000 / portTICK_RATE_MS) == NO_ERROR)
		i2c_cmd_link_delete(cmd);
		status = true;
	else
	return status;
Jstar88
Re: I2C latency
Postby Jstar88 » Sat Feb 17, 2018 6:09 pm
Just solved keeping I2C open and sending a buffer of data!
Users browsing this forum: No registered users and 134 guests
