make (gcc?) color output during build
ehiller
Postby ehiller » Thu Feb 22, 2018 5:14 pm
I'm trying to give my build-process output some intelligibility by adding color to the output. With the underlying compiler being gcc, I thought all I would have to do is add some flags
CFLAGS += -fdiagnostics-color=always
CXXFLAGS += -fdiagnostics-color=always
CPPFLAGS += -fdiagnostics-color=always
To be sure I set the GCC_COLORS environment variable ( both in my environment (with export) and in the Makefile.
GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
I even tried adding directly to the compiler variable
CC += -fdiagnostics-color=always
Am I missing a glaring step?
Re: make (gcc?) color output during build
Postby ESP_Sprite » Sat Feb 24, 2018 3:54 am
Are you sure you're using the latest toolchain? The one I have gives colorful warnings etc out of the box.
ehiller
Postby ehiller » Sun Feb 25, 2018 4:20 pm
I'm pretty sure:
esp32_win32_msys2_environment_and_toolchain-20180110
I can have the logs from the ESP32 itself be colorized. Just not GCC/make
Users browsing this forum: hugerobber, manas_frinso, MicroController and 121 guests
