ESP32 tools config very difficulty , why not have chinese?? But you Establish Company In China
jinshan010
Postby jinshan010 » Sun Mar 04, 2018 3:30 am
ESP32 tools config is very difficulty in the windows. The document in the web write very poor,many step is very ambiguous.I have try many times ,all are failure.The config explain have so many skip, but I don't know how to config. The eclipse ,many people is using,why not write a detailed document?? ESP32的工具配置太繁琐了,网站的说明文档很不详细,希望可以把文档写清楚一些,为什么不能有中文的配置文档呢?
ESP_krzychb
Contact:
Re: ESP32 tools config very difficulty , why not have chinese?? But you Establish Company In China
Postby ESP_krzychb » Sun Mar 04, 2018 11:42 am
Hi jinshan010,
jinshan010 wrote:ESP32 tools config is very difficulty in the windows.
I am sorry to hear that you have difficulty to configure ESP-IDF for Windows. A new build system to improve IDE integration is in preparation.
jinshan010 wrote:The document in the web write very poor,many step is very ambiguous.I have try many times ,all are failure.The config explain have so many skip, but I don't know how to config.
Chinese version of documentation how to set up ESP-IDF for Windows is under https://docs.espressif.com/projects/esp ... setup.html.
Do you refer to these documents?
* If so, then what particular steps are ambiguous and what would you like to improve?
* What do you think is skipped and should be added?
jinshan010 wrote:The eclipse ,many people is using,why not write a detailed document??
Instructions in Chinese how to set up Eclipse are in preparation and should be available soon.
EDIT> It is available under https://docs.espressif.com/projects/esp ... setup.html
Users browsing this forum: usulrasolas and 19 guests
