ESP board resets when opening com port
der_Phil
Postby der_Phil » Tue Mar 13, 2018 8:15 am
Hi experts,
I use a ESP Wroom 32 on a ESP32 Feather Board
see: https://www.adafruit.com/product/3707
With this, I managed to rebuild this project: https://learn.adafruit.com/thermal-came ... y/overview
I somehow want to extend the project, by saving images on aSD card and transfer them over the USB connector...hence I establish a serial connection using a com port.
My question is a follows.
Using the Arduino IDE I can open/close the com port as expected.
When I open/close the com port with 3rd party software, the board resets...why?
I found this in the internet for an Arduino:
https://tushev.org/articles/arduino/22/ ... ens-closes
You should set Data Terminal Ready (DTR) parameter for port to false\disabled. Without that signal, Arduino will not reset each time the port is opened or closed.
SerialPort p = new SerialPort(args[1], 9600);
p.DtrEnable = false;
p.Open();
p.Write(args[0]);
p.Close();
Is this also a possible solution for the ESP board?
Thank you,
Phil
thethinker
Re: ESP board resets when opening com port
Postby thethinker » Fri Mar 16, 2018 3:44 am
der_Phil wrote:Hi experts,
p.Open();
p.Write(args[0]);
p.Close();
Thank you,
Phil
If you look at the Schematic of the board you are talking about you can see that the RTS (Ready to send) pin of the USB<>SERIAL converter can also reset the chip, so you would have to disable that too.
rdaf2014
Postby rdaf2014 » Fri Sep 13, 2019 3:11 pm
I had similar problem. Each time I connected to my ESP32 from putty (serial), the ESP "rebooted".
I changed the flow control settings in Connection/serial from DSR/DTR to RTS/CTS.
Know i can connect and disconnect to my ESP32 without anoying resets.
Users browsing this forum: No registered users and 248 guests
