I'm trying to understand how to setup the Appearance charateristic in GAP BLE (in particular as REMOTE_GENERIC).
Here:
https://github.com/nkolban/esp32-snippets/issues/88
They seems to have fixed for ESP32-Arduino (mayb @chegewara and @kolban can help).
Here:
https://github.com/espressif/esp-idf/issues/1042
it is stated that it will available in v3.1.
I'm using ESP-IDF and I really don't know how to change it even if in
https://github.com/espressif/esp-idf/bl ... ap.c#L2664
it seems to be present something related to appearance characteristic.
How can I do it without nee to wait for v3.1?
Setup Appearance GAP characteristic (0x2A01) in BLE
Re: Setup Appearance GAP characteristic (0x2A01) in BLE
Hi.
When you creating ble server you have to prepare advertising data which is structure of type:
http://esp-idf.readthedocs.io/en/latest ... adv_data_t
In this structure you have field:
http://esp-idf.readthedocs.io/en/latest ... ppearanceE
which should be uint16_t (maybe its just typo in documentation).
Now you have to pass to this field hex value according to this table (this table is very ugly now, it used to be nicer)
https://www.bluetooth.com/specification ... arance.xml
Here you have few values that can passed for different HID devices:
https://github.com/nkolban/esp32-snippe ... .h#L20-L28
Or you can count it this way:
- value get from column 1 (category)
- left shift this value by 6 bits
- add value from sub-category column
This should have solve issue.
PS value will be decimal, not hex
PS2 for Generic Remote Control its: 6<<6 + 0 = 384
Just for test purpose i changed value in gatt_server example from esp-idf repo like this and it works:
static esp_ble_adv_data_t adv_data = {
.set_scan_rsp = false,
.include_name = true,
.include_txpower = true,
.min_interval = 0x20,
.max_interval = 0x40,
.appearance = 962, <--- ICON VALUE CHANGED
.manufacturer_len = 0,
.p_manufacturer_data = NULL,
.service_data_len = 0,
.p_service_data = NULL,
.service_uuid_len = 32,
.p_service_uuid = adv_service_uuid128,
.flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
Thanks @chegewara for suggestion.
What I miss to say in my first post was that I'm using raw data in order to emulate an eddystone UID beacon.
Therefore, I'm not using "esp_ble_adv_data_t" structure where "appearance" element is defined.
I currently setup two arrays for advertize and scan response in this way:
In scan_rsp_data I put the appearance "tag" (0x19) as reported in
https://www.bluetooth.com/specification ... ss-profile
The problem was that I setup in little-endian while it needs to be setup in big-endian. 384 = 0x0180 -> "0x80, 0x01"
So now it works and nRF Connect is able to scan and find the correct appearance (see image 1).
However, I'm testing GATTS_server_table_demo and when I connect the APP to the device, in the Generic Access section the Appearance value is not found (while Device Name is found probably because in the program it setup with "esp_ble_gap_set_device_name" function).
So probably my question should be: how to setup appearance in Generic Access section of GATT SERVER?
//Eddystone UID advertize
static uint8_t eddystone_adv_data[31] = {
0x02, 0x01, 0x06, //3
0x03, 0x03, 0xAA, 0xFE, //4
0x17, 0x16, 0xAA, 0xFE, 0x00, // 5
0x00, //1
0xe5, 0xf8, 0xf4, 0x9b, 0xf5, 0x61, 0xfc, 0x61, 0xf6, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, //16
0x00, 0x00 //2
static uint8_t eddystone_scan_rsp_data[] = {
// device name
0x06, 0x09, 'A', 'v', 'i', 'o', 'r',
//Appearance
0x03, 0x19, 0x80, 0x01, //384 = generic remote control
//flags
0x02, 0x01, 0x06,
//tx power
0x02, 0x0a, 0xdb
- image2.png (55.23 KiB) Viewed 9532 times
- image1.png (60.56 KiB) Viewed 9532 times
Here is the problem. We were able to set appearance only for advertising. I did some reaserch but i could not find any API that let you setup value for characteristic 0x2A01 (appearance). There is two options:
- its a bug and appearance characteristic value is not set even if its set for advertising,
- we are missing some API.
My suggestion is to open issue on github then you will get answer faster than here.
Sorry but i cant help you more with this issue.
OK @chegewara, you gave me a lot of help.
I will open an issue on github referencing this thread. Hopefully they could give a solution.
This can now be set using esp_ble_gap_config_local_icon() on both Arduino and the IDF.
Users browsing this forum: ESP_Roland and 149 guests
