This issue has been dealt with many times -- but I have two new DevKitC's that I can't download code. Both operate in exactly the same way -- so I am thinking that it is something to do with my setup? My procedure has been to reset the ESP32 with the enable switch, then press "Boot". I then run "make flash" on my Linux command line terminal.
1. Not sure why the flash size can not be detected
2. I don't know what "boot:0x13" means
3. Don't know why I am experiencing a flash read error on both my samples
I am not sure I know what to do next -- any help will be greatly appreciated.
I running the ESP-IDF under linux. Trying to get the "hello_world" example to run:
iot@Mercury:~/esp/hello_world$ make flash
Flashing binaries to serial port /dev/ttyUSB0 (app at offset 0x10000)...
esptool.py v2.3.1
Connecting........_
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
Flash params set to 0x0220
Compressed 19696 bytes to 11646...
A fatal error occurred: Timed out waiting for packet content
/home/iot/esp/esp-idf/components/esptool_py/Makefile.projbuild:54: recipe for target 'flash' failed
make: *** [flash] Error 2
A terminal program connected to the devKit reports a flash error:
iot@Mercury:~/esp/hello_world$ cat /dev/ttyUSB0
ets Jun 8 2016 00:22:57
flash read err, 1000
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
Timed Out waiting for packet content -- DevKitC
Re: Timed Out waiting for packet content -- DevKitC
It looks like they're failing to talk to the flash chip. Is anything connected to the pins of the DevKitCs?
Doesn't the first part of the preamble ( connecting ... chip ID is .....) indicate that my PC and the chip are communicating? There nothing other than the USB cable from the PC connected to the DevKitC and a power supply connection to the 5V pin and ground.
The log preamble seems to indicate that the tool is communicating with the chip -- I think, I am not sure what the boot error code means though. Can anyone point me to documentation or interpret
Users browsing this forum: Baidu [Spider] and 186 guests
