Explicitly exclude components (howto)
ninjaneer
Postby ninjaneer » Fri Apr 06, 2018 5:00 pm
Hey!
I've noticed that there's no make variable to exclude components to cut down on full build times, so I've created one for myself.
On about line 150 of IDF_PATH/make/project.mk, add the following after "COMPONENTS := $(sort... endif" and before "export COMPONENTS" :
ifdef EXCLUDE_COMPONENTS
COMPONENTS := $(filter-out $(EXCLUDE_COMPONENTS), $(COMPONENTS))
$(info Excluded components: $(EXCLUDE_COMPONENTS))
endif
$(info Component list: $(COMPONENTS))
Now in the project Makefile, you can have something like:
PROJECT_NAME := SomeSensorProject
EXCLUDE_COMPONENTS := openssl aws_iot bt coap nghttp
include $(IDF_PATH)/make/project.mk
I've only tested it with the msys32 subsystem under eclipse, but it's generic makefile language so hopefully it will work everywhere.
If interested, give it a try to see how it works for you.
Re: Explicitly exclude components (howto)
Postby ESP_Sprite » Sat Apr 07, 2018 3:13 am
Fyi, if you feel this is useful enough in general (and are willing to also modify the docs to mention this new variable), feel free to make a push request against the esp-idf github repo and we'll see if we can merge it into the master tree.
ninjaneer
Postby ninjaneer » Sat Apr 07, 2018 7:28 am
Will do... it's a marginal gain with the IDF when building clean, but I think anyone dealing with an underpowered automated build server might appreciate it.
javaben
Postby javaben » Sat Apr 07, 2018 10:53 pm
I would like to endorse this addition as I think it would facilitate unit test builds as separate constructs.
In eclipse, I would like to use the 'Build Configuration' for different builds, but it doesn't appear that the different configurations make their way into the esp-idf build. For instance, on Eclipse, I set up 'release', 'debug', and 'unittest', and then leave out certain 'components' and alternative 'app_main' source files based on the configuration, but everything appears to build regardless of which 'build configuration' is 'active', so the suggestion above might facilitate this.
Users browsing this forum: No registered users and 17 guests
