Mutex without FreeRTOS
michprev
Postby michprev » Sun Apr 08, 2018 10:12 am
what is the correct way to implement simple mutex to share date between Core 0 (FreeRTOS) and Core 1 (without FreeRTOS)? There is a simple example for ARM: http://infocenter.arm.com/help/index.js ... 03s02.html.
ESP_igrr
Re: Mutex without FreeRTOS
Postby ESP_igrr » Sun Apr 08, 2018 2:07 pm
You can build some form of mutual exclusion on top of the atomic compare-and-set instruction.
Here's the basic C wrapper for it: https://github.com/espressif/esp-idf/bl ... #L273-L290
Xtensa port of FreeRTOS has its spinlocks (portMUX_TYPE) built on top of it: https://github.com/espressif/esp-idf/bl ... ort.c#L302 (the link is to an older version, because the most recent one in master branch is a bit more complicated due to external RAM support).
michprev
Postby michprev » Thu Apr 12, 2018 10:26 pm
Is there any option for dual-core mutex? E. g. what happens when both cores access the same peripheral register / memory segment?
ESP_Sprite
Postby ESP_Sprite » Fri Apr 13, 2018 2:58 am
That is what the spinlock is for. On unicore systems, just disabling the interrupts is enough, but on multicore you need spinlocks.
Users browsing this forum: Google [Bot] and 20 guests
