[FATFS] filename and extension not preserving case-sensitive style
davdav
Postby davdav » Tue Apr 17, 2018 9:08 am
Hi everybody,
We use file system FATFS to store some files. File should be saved with "case-sensitive" name (i.e. "FOO.txt" is different from "foo.txt"). However I have checked that FATFS choose at its rights the name and extension upper-case, lower-case or camel-case..
In practice if I write a file with name "foo.TXT" with code
	FILE *fp = fopen("/D/SYSTEM/foo.TXT", "w");
	if (fp != NULL)
		if (fclose(fp) == 0)
			Error = FALSE;
and then I read the dicrtory with code
DIR* dir;				// pointer to the scanned directory.
struct dirent* entry;	// pointer to one directory entry.
dir = opendir("/D/SYSTEM");
if (!dir)
	ESP_LOGD(TAG_FS, "Failed to open dir %s for reading:%d", stringIn, errno);
else
	// scan the directory
	while ((entry = readdir(dir)))
		ESP_LOGD(TAG_FS, "file:%s", entry->d_name);
	closedir(dir);
I got from debug
D (2568348) fs: file:foo.txt
In practice the extension of the file has been lower-cased. Is it correct a behaviuor like this?
Shouldn't I rely on the case sensitive of FATFS?
ESP_Sprite
Re: [FATFS] filename and extension not preserving case-sensitive style
Postby ESP_Sprite » Tue Apr 17, 2018 9:38 am
FAT filesystems always are case-insensitive, as far as I know. (See here, page 30: "All types of search operations within the file system (i.e. find, open, create, delete, rename) are case-insensitive.") I think Linux has a mode to mount it case-sensitively, but that's more-or-less a hack.
davdav
Postby davdav » Tue Apr 17, 2018 10:45 am
Thank you @ESP_sprite, in effect it seems FAT is case-insensitive and my approach was wrong.
So we need to find another solution to "sign" a file..
Users browsing this forum: No registered users and 274 guests
