how to set up the right IDF_PATH for copy the hello-world example
mkseven32
Postby mkseven32 » Mon Apr 23, 2018 1:32 am
Hi
follow the ESP-IDF Programming Guide , it shows set up the IDF_PATH as like below:
export IDF_PATH="C:/msys32/home/11022259/esp/esp-idf"
when i set it right and then to copy the hello-world example to esp directory , it always noting a error that could not find the file or directory.
$ cp: 无法获取'F:/msys32/home/11022259/esp/esp-idf/examples/get-started/hello-world' 的文件状态(stat): No such file or directory
ESP_Angus
Re: how to set up the right IDF_PATH for copy the hello-world example
Postby ESP_Angus » Mon Apr 23, 2018 2:23 am
If you run the command "pwd" (for "print working directory") when the prompt shows "~/esp", what does it print?
If you run the command "ls" (for "list") when the prompt shows "~/esp", what does it output then? Can you see the esp-idf directory there?
mkseven32
Postby mkseven32 » Mon Apr 23, 2018 2:43 am
hi
it is like the attched pic shows
ESP_Angus
Postby ESP_Angus » Mon Apr 23, 2018 3:35 am
If MSYS32 is installed in F:/MSYS32 then this looks like it should work.
You could try changing the IDF_PATH variable value to "/home/11022259/esp/esp-idf" instead and see if this resolves the issue.
chegewara
Postby chegewara » Mon Apr 23, 2018 4:25 am
On windows in msys32 absolute path to esp-idf looks like this:
export IDF_PATH=/disk_letter/root_folder/subfolder/esp-idf
example:
export IDF_PATH=/C/msys32/home/11022259/esp/esp-idf
mkseven32
Postby mkseven32 » Mon Apr 23, 2018 5:22 am
thanks for everyone , it is the problem of "-" in the hello_world project name.
which right is "hello_world" while i write a wrong name as "hello-world"~~~~~
Users browsing this forum: No registered users and 131 guests
