i have sometimes a problem when i want to debug in eclipse.
Sometimes when i start debugging the process hangs in Thread#1 Running: User Request (See Picture).
Then i have to stop debugging and try it again.
Sometimes i have to stop and try it 10 times or more to get at the breakpoint in app_main.
Has anyone a solution?
Problem with Debugging in Eclipse
- 2018-04-25 08_25_47-Debugging.png (62.36 KiB) Viewed 4494 times
Re: Problem with Debugging in Eclipse
Could you attach gdb and openocd logs? You can find the instructions how to do this here http://esp-idf.readthedocs.io/en/latest ... ing-issues.
here are the logs.
Now the debugger hangs in another section.
here are the logs.
- thread1.png (65.29 KiB) Viewed 4465 times
- openocd_log.txt
- (755.84 KiB) Downloaded 818 times
- gdb_log.txt
- (13.94 KiB) Downloaded 806 times
Users browsing this forum: No registered users and 254 guests
