confusing stack traces
timredfern
Postby timredfern » Fri Jun 15, 2018 2:55 pm
I'm seeing some inexplicable crashes in my esp-idf application. The stack traces look like this:
Guru Meditation Error: Core 0 panic'ed ()
Core0 register dump:
PC      0846  PS      0604  A0      0d32  A1      fb10  : 0x0000: 0f1d: 000f: 0000
Afb44  0008  082e  fb10  : 0000: 0007: 0000: 0f1f
A0007  0000  0008  0005  : 0000: 00c8: 00c9: 0000
0846:0fed 0x06cfb20
1 r0652  06b4  0832  fbc0  : 0000: 0000: 0000: 0fc
EspStackTraceDecoder.jar says:
Exception Cause: Not found
No Addresse found in Stracktrace!
There's also this:
oe1 eitrdm: oe pnce Itrutwttmoto P1
2    x3fb3c A   :00001 4    x0000 A   :00001
1    x0000 A1  :00011 1    x0000 A3  :0fa8 b
XVDR x0000 LE  :000c2 ED   x409 LON :00000
EC  :006b5 P2   x0000 P3   x0000 EC  :04157f
C    x407 P   :00604 0    x80a A   :0ff0 x41f:x0000
6    x3fb0c A   :00001 8    x0000 A   :005
1    x0000 A5  :00000 A    x0001 ECAS:00006 0
ECAD:00000 BG   x404 LN  :000c3 CUT  xffff
Rboig.00c210ff0 x40a:x3fc11 x405:x3fc13 x400e:x0000
Martian?
I kind of suspect that the antenna is picking up stray EMFs from an electric motor and this causes the crash. Any ideas?
timredfern
Re: confusing stack traces
Postby timredfern » Fri Jun 15, 2018 5:27 pm
oe0 eitrdm: oe pnce Itrutwttmoto P0
2    x3fba A   :004 4    x0001 A   :0f5d0 fb0
1    x000 A1  :00603 1    x803 A3  :0f5a0
C    x407 P   :00604 0    x80a A   :0f0 400e:x0000
6    x3fb0c A   :00001 8    x0000 A   :005 0b
1    x0000 A5  :00001 A    x0001f ECAS:00005
Bctae x407:x3fc2b008bd50f0008d280f0008d200861
and
2    x3fb7 A   :0fc0 4    x0006 A   :000d7 c7
1    x0000 A1  :0fc0 1    x3fc27 A3  :00000
XVDR x0000 LE  :000c2 ED   x40 LON :0ffff 0
akrc:008460f0 x412b:x3fc2c003c000fc0
oe1 eitrdm:
2    x3fc0c A   :004 4    x0001 A   :0fd0 fc1
1    x000 A1  :004 1    x80 A3  :0fa0 f3a6
This looks to me like the console is printing every other character: `akrc:` or `Bctae` for `Backtrace:`
nb I'm using the Esp-prog debugger device with a custom board that has a very simple design based on the reference. The console UART is connected by a 10cm ribbon cable.
Users browsing this forum: Bing [Bot] and 228 guests
