I2S Audio Input-Output Distortion
robert_kuramshin
Postby robert_kuramshin » Fri Jun 15, 2018 9:10 pm
Hey,
I am in the process of integrating the ESP32 with a MAX98091 codec for two way communication over I2S. So far I have been having problems with reading data over DMA and playing it back.
I am using an devkit for the codec which allows me to take an I2S audio input from my computer and have the codec play it through some headphones. In order to debug reading and writing from the I2S DMA, I disconnected the jumpers that connect the input I2S from the computer to the codec, and put my ESP32 "in the middle". So now I am getting an I2S signal from my computer going into the ESP, and then back out via another I2S channel to the codec.
So far I am able to read about a second (I think?) of audio and play it back right after, but with a large amount of distortion (talking is not describable and music is barely recognizable).
I am wondering if anyone has some tips for what I should try doing to get this to work. I've done some basic stuff like playing with the sample rates, sizes, and DMA buffer sizes without much success.
Here is the code:
#include <stdio.h>
#include "freertos/task.h"
#include "driver/i2s.h"
#include "esp_system.h"
#define SAMPLE_RATE     (16000)
#define SAMPLE_SIZE     (16)
uint8_t *buf;
static void test(void)
    i2s_start(0);
    size_t bytes_read = 0;
    i2s_read(0, buf, SAMPLE_RATE*SAMPLE_SIZE/4,&bytes_read, 1000);
    printf("Read: %d bytes\n", bytes_read);
    i2s_stop(0);
    i2s_start(1);
    size_t bytes_written = 0;
    i2s_write(1, buf, SAMPLE_RATE*SAMPLE_SIZE/4,&bytes_written, 1000);
    printf("Wrote %d bytes\n",bytes_written);
    i2s_stop(1);
    //i2s_zero_dma_buffer(0);
    //i2s_zero_dma_buffer(1);
void app_main()
    i2s_config_t i2s_config = {
        .mode = I2S_MODE_MASTER | I2S_MODE_RX,
        .sample_rate = SAMPLE_RATE,
        .bits_per_sample = SAMPLE_SIZE,
        .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
        .communication_format = I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB,
        .dma_buf_count = 32,
        .dma_buf_len = 64,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1
    i2s_pin_config_t pin_config = {
        .bck_io_num = 26,
        .ws_io_num = 25,
        .data_out_num = -1,
        .data_in_num = 12
    i2s_config_t i2s_config_2 = {
        .mode = I2S_MODE_MASTER | I2S_MODE_TX,
        .dma_buf_len = 64,
    i2s_pin_config_t pin_config_2 = {
        .bck_io_num = 27,
        .ws_io_num = 33,
        .data_out_num = 32,
        .data_in_num = -1
    i2s_driver_install(0, &i2s_config, 0, NULL);
    i2s_set_pin(0, &pin_config);
    i2s_driver_install(1, &i2s_config_2, 0, NULL);
    i2s_set_pin(1, &pin_config_2);
    buf = calloc(SAMPLE_RATE*8,sizeof(char));
    while (1) {
        test();
Codec:
https://www.maximintegrated.com/en/prod ... 3TQFN.html
Thanks!
- Rob
robert_kuramshin
Re: I2S Audio Input-Output Distortion
Postby robert_kuramshin » Mon Jun 25, 2018 3:17 pm
For those who are interested, I ended up fixing the problem last week.
I moved away from using the USB DAC, and just connected the codec directly to the ESP32 for both input and output. I tried using the codec in master mode for a while, but it seemed like I would always get distorted data coming from the microphone. However, as soon as I switched the codec to slave mode everything started to work perfectly. I never traced down the root of the problem, but looks like something goes wrong when reading I2S with the ESP32 in slave mode (getting clock signals from codec).
The final code is pretty similar. The only differences are that there is now only one I2S channel set up in master mode for both tx and rx, and that I write the buffer length worth of bytes at a time.
Thanks,
-Rob
chris-kuhr
Postby chris-kuhr » Thu Jan 07, 2021 5:18 pm
Setting the input i2s port as slave helped me as well!
Thank you for finding this.
Users browsing this forum: ESP_ondrej and 222 guests
