Rf based positioning using phase differences
There are certain conditions to which the RF-PHY must comply in order to be able to work for phase-based ranging, such as access to I / Q signals and a PLL that continues between TX / RX switching. Does the ESP32 complies with this or is this a limitation by the ESP32?
Re: Rf based positioning using phase differences
I think the hardware actually should have support for this (with a few restrictions, as in, if I recall correctly it only works for certain encodings), however the drivers do not have functionality to output the associated data yet. Also, the functionality is mostly untested so we don't know if it works in practice.
Hold that thought: something has been recently merged. Does https://esp-idf.readthedocs.io/en/lates ... nformation do what you want?
I don't see anything in this documentation that gives access to i/q signals.
.Each item is stored as two bytes: imaginary part followed by real part
It seems that the ESP32 can not transmit unmodulated carriers and is therefore not supported for phase-based ranging.
Users browsing this forum: Baidu [Spider], ESP_Roland, Google [Bot] and 286 guests
