Extremely slwo build time in eclipse (not in MSYS)
mehdio
Postby mehdio » Thu Jul 05, 2018 5:38 pm
Hello all,
I have an issue with Eclipse.
Everything was working fine but building time was a little bit slow. Quite normal under windows 10 and MSYS32.
For other reasons i tried activating WSL on windows. Since that moment, building under Eclipse didn't work. So i disabled WSL and now building works again. I did many things so not 100% sure it was the problem.
Problem is, it's now extremly slow. I tried building the helloworld through Eclipse and i'm at 11 minutes and it still at 31% !!
If i do this in MSYS32, i build in approx 1 minute and a half with a -j4. Still a long time for a simple example but this is consistent with what i had before in eclipse.
Any idea how i could have messed up my Eclipse build time ? and what i should do to correct this?
mehdio
Re: Extremely slwo build time in eclipse (not in MSYS)
Postby mehdio » Fri Jul 06, 2018 11:18 am
If i run the python script in MSYS32, i also have a very long build time (more than hour).
So this is not related to eclipse.
Any idea?
luisonoff
Postby luisonoff » Mon Jul 09, 2018 6:44 am
I had a similar issue in the past and it was caused by an antivirus/antimalware intensively checking files created during compilation.
Try disabling any antivirus/antimalware software or create an exception on the compilation folder.
papaluna
Postby papaluna » Tue Jul 10, 2018 10:16 pm
FYI these are the instructions I use on MS WIndows developer machines to speedup the make:
### IMPROVE MAKE's PERFORMANCE*** WINDOWS DEFENDER: DISABLE CHECKING THE MSYS2 FOLDER and MYIOT FOLDER
Windows Defender => Virus & Thread Protection => Virus & Thread protection settings => Exclusions:
	EXCLUDE DIR c:\msys32\
	EXCLUDE DIR c:\myiot\
### PROBLEM FIXING FIX for error ""error: cannot fork() for fetch-pack: Resource temporarily unavailable"" when doing Git push issues
#GITCMD>
\msys32\autorebase.bat
Paul.
tangqingcai
Postby tangqingcai » Fri Jul 27, 2018 7:20 am
mark;
Does anyone have resolved this problem?
fly135
Postby fly135 » Fri Jul 27, 2018 3:16 pm
Disable windows Defender from scanning your dev directory. (i.e. the build directory creates tons of files to scan). When using make, you can specify how many threads with -j option. So if you have a quad core w/ 2 threads per core then use 8.
make -j8
John A
Deouss
Postby Deouss » Fri Jul 27, 2018 3:41 pm
I am using CMake IDF and average fresh compilation of very large project takes no longer than 10s and less than 20s with flashing.
It is like 2-3s after first compilation :)
We should all switch to CMake
Users browsing this forum: No registered users and 50 guests
