SPIFFS example error - "spiffs partition could not be found"
FShiwani
Postby FShiwani » Mon Jul 09, 2018 6:04 pm
I'm trying to run the SPIFFS example (https://github.com/espressif/espidf/blo ... ple_main.c)
However, I am getting the following error
E (276) SPIFFS: spiffs partition could not be found
E (276) example: Failed to find SPIFFS partition
I've tried using the parititions_example.csv file by configuring through "make menuconfig" - no luck, it doesn't even flash. Not sure what I'm missing.
adanvasco
Re: SPIFFS example error - "spiffs partition could not be found"
Postby adanvasco » Thu Dec 19, 2019 1:11 am
A year later, but this question actually gave me the idea of checking the actual partition table when I was facing the same error.
Make sure yours contain a line named storage, with type data, subtype spiffs, and then the size, in my case 0xF0000.
I hope this helps someone.
Users browsing this forum: Google [Bot] and 103 guests
