1. i'm using the esp BLE libaray, and I would like to know if there is a way to program the ble physical layer of the esp32 by the sdk (e.g. : setting the desire frequency, or blocking some Frequencies of hopping)?
2. The BLERemoteCharacteristic.cpp uses header named "esp_gattc_api.h", and I want to edit some functions which are inside of that header, but I can't locate the cpp file of that header (esp_gattc_api.cpp). how can I edit those functions (e.g: esp_ble_gattc_write_char)?
Thank you in advace!
ESP BLE
Re: ESP BLE
Hey, thank you for your comment!
I just realized I only have installed the "arduino-esp32" and not the "esp-idf" as in your link.
do I need to download the "esp-idf" also in order to access those files? what is the different between the repositories?
I'm alittle confused, how come it does compile and work while I use some cpp files which I cant find on my comp?
I'm new to the esp32, so thank you understanding!
Re: ESP BLE
It would be easier if you say what do you need to change in esp_ble_gattc_write_char.
According point 1, it is possible to set hopping channels in esp-idf but it is not implemented in arduino library. You can change this line on your computer:
https://github.com/nkolban/esp32-snippe ... ng.cpp#L57
wit those ORed values:
https://github.com/espressif/esp-idf/bl ... #L223-L225
Users browsing this forum: Baidu [Spider] and 280 guests
