Is Lolin32 CE and FCC compliant or just the SOC Transceiver?
Posted: Tue Jul 31, 2018 8:47 am
by imovit
Hi
I know that lolin32 is retired... I probably will use the new boards in order to implement a 'commercial' project part.
As I can not get into the product website, my question is:
Is the entire board CE and FCC compliant (ready to market) or only the soc transceiver is CE and FCC compliant?
Looking to the board, only the soc has the marks
Re: Is Lolin32 CE and FCC compliant or just the SOC Transceiver?
Posted: Tue Jul 31, 2018 5:20 pm
by WiFive
Just the module. When you add circuits you need to retest anyway.
Posted: Tue Jul 31, 2018 6:14 pm
by imovit
Which module?
Do you mean the transceiver module or the whole board?
Imagine I just want to implement a gateway BLE->Wifi. The board will be used as is (just an USB cable for power)
Is the whole board certified (Lolin32) or just the transceiver SOC?
Are you the manufacturer? Certificate publishing would be interesting...
Thanks a lot
Posted: Wed Aug 01, 2018 4:28 am
by WiFive
No you would have to ask WEMOS. WROOM-32 has some modular certifications by itself. But that doesn't cover everything and you still have to do Bluetooth SIG testing/listing. If you are going to sell it in an enclosure you are technically supposed to test that way. Dev boards are a lot of times exempt from compliance testing so they probably didn't do it. Basically you should consult a test lab and figure out what you need.
Posted: Wed Aug 01, 2018 8:21 pm
by imovit
It is clear that WROOM-32 is certified because it has the logos. But the LOLIN32 board could not be. Hence my question to the board.
I thought it was a ready-to-market board but may be it is not. :-(
I have to find an alternative.
Thanks a lot
