Hi, I downloaded the ESP32-at source code from git server but i'm unable to make using command line .
Procedure given in git is not clear.
when i make i'm getting this error,
generating ble_data.bin: python /home/nkspr/atcmd/esp32-at/tools/BLEService.py - t /home/nkspr/atcmd/esp32-at/build/customized_partitions/ble_data.bin /home/nksp r/atcmd/esp32-at/components/customized_partitions/raw_data/ble_data/example.csv
File "C:/msys32/home/nkspr/atcmd/esp32-at/tools/BLEService.py", line 29, in <m odule>
import yaml
ImportError: No module named yaml
make: *** [/home/nkspr/atcmd/esp32-at/components/customized_partitions/Makefile. projbuild:45: /home/nkspr/atcmd/esp32-at/build/at_customize.bin] Error 1
Anybody help me to make and flash?
thanks,
ESP32-at- How to execute the source code for ESP32-at?
Re: ESP32-at- How to execute the source code for ESP32-at?
It says "No module named yaml", maybe you can follow the guide https://github.com/espressif/esp32-at/tree/master/tools
hi,
I fixed. I redo all installation and make process from beginning then it become solved.
Anybody know how to configure change AT command port from UART1 to UART0 using config menu? I tried but unable to do.
thanks,
thanks,
Users browsing this forum: No registered users and 264 guests
