mg_broadcast not working
snahmad75
Postby snahmad75 » Sun Aug 19, 2018 4:24 pm
namespace
	static void ev_handler(struct mg_connection *nc, int ev, void *ev_data)
		switch (ev) {
		case MG_EV_POLL:
		case MG_EV_SEND:
		case MG_EV_ACCEPT:
		case MG_EV_CONNECT:
		case MG_EV_RECV:
		case MG_EV_CLOSE:
		default:
void sendUDPMessages()
	ACDTRACEF(ES_NoError, "Enter sendUDPMessages \n");
	struct mg_mgr mgr;
	mg_mgr_init(&mgr, NULL);
	struct mg_connect_opts opts;
	memset(&opts, 0, sizeof(opts));
	opts.flags = MG_F_ENABLE_BROADCAST;
	opts.iface = nullptr;
	const char *port1 = "udp://1457", *port2 = "udp://127.0.0.1:1457";
	const char *port3 = "udp://255.255.255.255:1457";
	struct mg_connection * nc_client = mg_connect_opt(&mgr, port3, ev_handler, opts);
	bool stop = false;
	std::thread thread = std::thread([&]() {
		while (!stop) {
			mg_mgr_poll(&mgr, 1);
	for (int i = 1; i <= 10; i++)
		std::string  send_msg = "hello";
		mg_broadcast(&mgr, ev_handler, (void*)send_msg.c_str(), send_msg.size());
	std::this_thread::sleep_for(std::chrono::seconds(3));
	stop = true;
	if (thread.joinable()) {
		thread.join();
	mg_mgr_free(&mgr);
Here is my example code.
mg_broadcast not working/ doing nothing on windows platform.
On ESP32 platform it does not build. linker error with mg_broadcast
kolban
Re: mg_broadcast not working
Postby kolban » Sun Aug 19, 2018 5:18 pm
I had a google on mg_broadcast and esp32 as search terms and there appears to be a number of stories related to that. Have you performed a similar search? Understand that the mg_broadcast capability is part of the Mongoose libraries and is not really related to the Espressif/ESP-IDF code bases. Obviously if Mongoose are using an ESP-IDF function and it isn't working as described, then ESP32 folks will want to hear that ... but for usage of a third party library, it is likely you will want to consult with that third party first.
snahmad75
Postby snahmad75 » Sun Aug 19, 2018 10:11 pm
ok, I will ask on mongoose web server forum.
Users browsing this forum: No registered users and 131 guests
