I'm uploading files via POST Multipart messages (see viewtopic.php?f=13&t=7801&p=33058#p33058)
Instead of using esp_http_client_perform, I had to use esp_http_client_write for writing the body, since the full files will not fit inside the memory.
the issue is that after about 2 seconds the esp_http_client_write returns -1
Output:
I (5695) event: sta ip: 192.168.0.122, mask: 255.255.255.0, gw: 192.168.0.254
D (5695) WIFI: SYSTEM_EVENT_STA_GOT_IP
I (5695) WIFI: Connected to AP, begin http example
I (5695) WIFI: url = http://192.168.0.119:8080/api/log/upload
I (5705) WIFI: client initialized
I (5705) WIFI: sending file: LOG_181019_192602.zip
I (5705) SD: Opening file /sdcard/LOG_181019_192602.zip, rb
I (5725) WIFI: keyHeader: --MyBoundary
Content-Disposition: form-data; name="key"
${filename}
I (5725) WIFI: requestHead: --MyBoundary
Content-Disposition: form-data; name="file"; filename="LOG_181019_192602.zip"
Content-Type: application/zip
I (5745) WIFI: tail:
--MyBoundary--
I (5745) WIFI: length: 312197
D (5905) WIFI: HTTP_EVENT_ON_CONNECTED
I (5905) WIFI: client connection open
I (5905) WIFI: keyHeader: 73
I (5905) WIFI: requestHead: 130
I (5915) WIFI: write file: 1000/1000
I (5925) WIFI: write file: 1000/1000
I (5935) WIFI: write file: 1000/1000
I (6005) WIFI: write file: 1000/1000
I (6015) WIFI: write file: 1000/1000
I (6025) WIFI: write file: 1000/1000
I (6035) WIFI: write file: 1000/1000
I (6045) WIFI: write file: 1000/1000
I (6205) WIFI: write file: 1000/1000
I (6215) WIFI: write file: 1000/1000
I (6225) WIFI: write file: 1000/1000
I (6235) WIFI: write file: 1000/1000
I (6315) WIFI: write file: 1000/1000
I (6325) WIFI: write file: 1000/1000
I (6335) WIFI: write file: 1000/1000
I (6345) WIFI: write file: 1000/1000
I (6415) WIFI: write file: 1000/1000
I (6425) WIFI: write file: 1000/1000
I (6435) WIFI: write file: 1000/1000
I (6515) WIFI: write file: 1000/1000
I (6525) WIFI: write file: 1000/1000
I (6535) WIFI: write file: 1000/1000
I (6545) WIFI: write file: 1000/1000
I (6625) WIFI: write file: 1000/1000
I (6625) WIFI: 38000/311974 bytes sent total 37.11 KiB/s
I (6625) WIFI: 39000/311974 bytes sent total 38.09 KiB/s
I (6635) WIFI: write file: 1000/1000
I (6635) WIFI: 40000/311974 bytes sent total 39.06 KiB/s
I (6645) WIFI: write file: 1000/1000
I (6645) WIFI: 41000/311974 bytes sent total 40.04 KiB/s
I (6655) WIFI: write file: 1000/1000
I (6655) WIFI: 42000/311974 bytes sent total 41.02 KiB/s
I (6715) WIFI: write file: 1000/1000
I (6715) WIFI: 43000/311974 bytes sent total 41.99 KiB/s
I (6725) WIFI: write file: 1000/1000
I (6725) WIFI: 44000/311974 bytes sent total 42.97 KiB/s
I (6735) WIFI: write file: 1000/1000
I (6735) WIFI: 45000/311974 bytes sent total 43.95 KiB/s
I (6735) WIFI: 46000/311974 bytes sent total 44.92 KiB/s
I (6745) WIFI: write file: 1000/1000
I (6745) WIFI: 47000/311974 bytes sent total 45.90 KiB/s
I (6755) WIFI: write file: 1000/1000
I (6755) WIFI: 48000/311974 bytes sent total 46.88 KiB/s
I (6765) WIFI: write file: 1000/1000
I (6765) WIFI: 49000/311974 bytes sent total 47.85 KiB/s
I (6825) WIFI: write file: 1000/1000
I (6825) WIFI: 50000/311974 bytes sent total 48.83 KiB/s
I (6835) WIFI: 51000/311974 bytes sent total 49.80 KiB/s
I (6835) WIFI: write file: 1000/1000
I (6835) WIFI: 52000/311974 bytes sent total 50.78 KiB/s
I (6845) WIFI: write file: 1000/1000
I (6845) WIFI: 53000/311974 bytes sent total 51.76 KiB/s
I (6855) WIFI: write file: 1000/1000
I (6855) WIFI: 54000/311974 bytes sent total 52.73 KiB/s
I (6855) WIFI: 55000/311974 bytes sent total 53.71 KiB/s
I (6865) WIFI: write file: 1000/1000
I (6865) WIFI: 56000/311974 bytes sent total 54.69 KiB/s
I (6925) WIFI: write file: -1/1000
D (6925) WIFI: HTTP_EVENT_DISCONNECTED
static bool sendFile(esp_http_client_handle_t client, const char *fileName)
esp_err_t err;
FILE *file;
char fileNameWithDir[100];
snprintf(fileNameWithDir, sizeof(fileNameWithDir), "/sdcard/%s", fileName);
file = SD_open(fileNameWithDir, "rb");
if(!file)
ESP_LOGW(TAG, "Could not open file to send through wifi");
return false;
unsigned fileLenght = 0;
struct stat st;
if(stat(fileNameWithDir, &st) == 0)
fileLenght = st.st_size;
time_t fileTransferStart = 0;
time(&fileTransferStart);
char contentType[] = "application/zip";
//key header
char keyHeader[100] = "";
strcat(keyHeader, "--");
strcat(keyHeader, HTTP_BOUNDARY);
strcat(keyHeader, "\r\n");
strcat(keyHeader, "Content-Disposition: form-data; name=\"key\"\r\n\r\n");
strcat(keyHeader, "${filename}\r\n");
ESP_LOGI(TAG, "keyHeader: %s", keyHeader);
//request header
char requestHead[200] = "";
strcat(requestHead, "--");
strcat(requestHead, HTTP_BOUNDARY);
strcat(requestHead, "\r\n");
strcat(requestHead, "Content-Disposition: form-data; name=\"file\"; filename=\"");
strcat(requestHead, fileName);
strcat(requestHead, "\"\r\n");
strcat(requestHead, "Content-Type: ");
strcat(requestHead, contentType);
strcat(requestHead, "\r\n\r\n");
ESP_LOGI(TAG, "requestHead: %s", requestHead);
//request tail
char tail[50] = "";
strcat(tail, "\r\n--");
strcat(tail, HTTP_BOUNDARY);
strcat(tail, "--\r\n\r\n");
ESP_LOGI(TAG, "tail: %s", tail);
//Set Content-Length
int contentLength = strlen(keyHeader) + strlen(requestHead) + fileLenght + strlen(tail);
ESP_LOGI(TAG, "length: %d", contentLength);
char lengthStr[10];
sprintf(lengthStr, "%i", contentLength);
err = esp_http_client_set_header(client, "Content-Length", lengthStr);
err = esp_http_client_open(client, HTTP_BUFFER_SIZE);
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to open HTTP connection: %s", esp_err_to_name(err));
ESP_LOGI(TAG, "client connection open");
ESP_LOGI(TAG, "keyHeader:\t%d", esp_http_client_write(client, keyHeader, strlen(keyHeader)));
ESP_LOGI(TAG, "requestHead:\t%d", esp_http_client_write(client, requestHead, strlen(requestHead)));
//Send file parts
char buffer[HTTP_BUFFER_SIZE];
unsigned fileProgress = 0;
int length = 1;
while(length)
length = fread(buffer, sizeof(char), HTTP_BUFFER_SIZE, file);
if(length)
int wret = esp_http_client_write(client, buffer, length);
ESP_LOGI(TAG, "write file:\t%d/%d", wret, length);
if(wret < 0)
return false;
fileProgress += wret;
//ESP_LOGI(TAG, "%.*s", length, buffer);
time_t now;
time(&now);
if((float)(now - fileTransferStart) / 1024 > 0)
ESP_LOGI(TAG, "%u/%u bytes sent total %.02f KiB/s", fileProgress, fileLenght, fileProgress / (float)(now - fileTransferStart) / 1024);
SD_close(file);
//finish Multipart request
ESP_LOGI(TAG, "tail:\t%d", esp_http_client_write(client, tail, strlen(tail)));
//Get response
ESP_LOGI(TAG, "fetch_headers:\t%d", esp_http_client_fetch_headers(client));
ESP_LOGI(TAG, "chunked:\t%d", esp_http_client_is_chunked_response(client));
int responseLength = esp_http_client_get_content_length(client);
ESP_LOGI(TAG, "responseLength:\t%d", responseLength);
int status = esp_http_client_get_status_code(client);
ESP_LOGI(TAG, "status:\t%d", status);
if(responseLength)
if(esp_http_client_read(client, buffer, responseLength) == responseLength)
ESP_LOGI(TAG, "Response: %.*s", responseLength, buffer);
err = esp_http_client_close(client);
ESP_LOGE(TAG, "Failed to close HTTP connection: %s", esp_err_to_name(err));
return status == 200 || status == 409;
static void https_send_file()
char url[200] = "http://192.168.0.119:8080/api/log/upload";
ESP_LOGI(TAG, "url = %s", url);
esp_err_t err;
.url = url,
.event_handler = _http_event_handler,
.cert_pem = howsmyssl_com_root_cert_pem_start,
esp_http_client_handle_t client = esp_http_client_init(&config);
ESP_LOGI(TAG, "client initialized");
err = esp_http_client_set_method(client, HTTP_METHOD_POST);
ESP_LOGE(TAG, "Failed to set method: %s", esp_err_to_name(err));
//Set Multipart header
char contentTypeStr[50] = "multipart/form-data; boundary=";
strcat(contentTypeStr, HTTP_BOUNDARY);
err = esp_http_client_set_header(client, "Content-Type", contentTypeStr);
err = esp_http_client_set_header(client, "Accept", "text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8");
err = esp_http_client_set_header(client, "Accept-Encoding", "gzip,deflate");
err = esp_http_client_set_header(client, "Accept-Charset", "ISO-8859-1,utf-8;q=0.7,*;q=0.7");
err = esp_http_client_set_header(client, "User-Agent", "Test");
err = esp_http_client_set_header(client, "Keep-Alive", "300");
err = esp_http_client_set_header(client, "Connection", "keep-alive");
err = esp_http_client_set_header(client, "Accept-Language", "en-us");
char fileName[] = "LOG_181019_192602.zip";
ESP_LOGI(TAG, "sending file: %s", fileName);
sendFile(client, fileName);
err = esp_http_client_cleanup(client);
ESP_LOGE(TAG, "Failed to clean HTTP connection: %s", esp_err_to_name(err));
vTaskDelete(NULL);
