Yes, when the expected output frequency is too low, we will choose ref_tick as the source clock. So, you can use ` ledc_timer_set` to configure the timer.loboris wrote: ↑Tue Dec 04, 2018 10:24 pmThis value can be set by set by ledc_timer_set() function (source).
clk_src parameter can be LEDC_APB_CLK or LEDC_REF_TICK
LEDC unstable frequency
Re: LEDC unstable frequency
wookooho
[solved] LEDC unstable frequency
tried it and it works. With power management enabled, frequency is now stable as it should be. Due to the lower timer input frequency, i had to reduce the resolution from 10 to 9 bit.
#include "esp_err.h"
#include "esp_log.h"
#include "driver/ledc.h"
#include "driver/periph_ctrl.h"
#include "soc/ledc_reg.h"
#define J1772_LEDC_TIMER LEDC_TIMER_0
#define J1772_LEDC_CHANNEL LEDC_CHANNEL_0
#define J1772_LEDC_TIMER_RES LEDC_TIMER_9_BIT
#define J1772_DUTY_MAX ((1 << LEDC_TIMER_9_BIT) -1 )
#define J1772_PWM_FREQUENCY_HZ 1000
#define J1772_LEDC_SPEEDMODE LEDC_HIGH_SPEED_MODE
void ledc_init() {
const char * ME = __func__;
esp_err_t err;
periph_module_enable(PERIPH_LEDC_MODULE);
uint32_t precision = J1772_DUTY_MAX + 1;
uint64_t div_param = ((uint64_t) LEDC_REF_CLK_HZ << 8) / J1772_PWM_FREQUENCY_HZ / precision;
if (div_param < 256 || div_param > LEDC_DIV_NUM_HSTIMER0_V) {
ESP_LOGE(ME, "requested frequency and duty resolution can not be achieved, try increasing freq_hz or duty_resolution. div_param=%d", (uint32_t ) div_param);
err = ledc_timer_set(LEDC_HIGH_SPEED_MODE, J1772_LEDC_TIMER, div_param, J1772_LEDC_TIMER_RES, LEDC_REF_TICK);
if (err) ESP_LOGE(ME, "ledc_timer_set returned %d",err);
ledc_timer_rst(J1772_LEDC_SPEEDMODE, J1772_LEDC_TIMER);
ESP_LOGD(ME, "ledc_timer_set: divider: 0x%05x duty_resolution: %d\n", (uint32_t) div_param, J1772_LEDC_TIMER_RES);
ledc_channel_config_t ledc_channel = {
.gpio_num = j1772_pilot_GPIO,
.speed_mode = J1772_LEDC_SPEEDMODE,
.channel = J1772_LEDC_CHANNEL,
.intr_type = LEDC_INTR_DISABLE,
.timer_sel = J1772_LEDC_TIMER,
.duty = J1772_DUTY_MAX,
.hpoint = 0 // TODO: AD 10.11.2018: new, does 0 work (0xfffff does not work)
err = ledc_channel_config(&ledc_channel);
ESP_LOGD(ME,"ledc_channel_config returned %d",err);
Users browsing this forum: mahone and 136 guests
