ESP32 BT write echo back once
joe@shkila.com
Postby joe@shkila.com » Sun Nov 18, 2018 1:47 pm
I'm new to esp32, and i want to use the bluetooth feature
I've taken the spp_accepter example and add it the spp_initiator example
here's the outcome:
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_bt_main.h"
#include "esp_gap_bt_api.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "time.h"
#include "sys/time.h"
#define SPP_TAG "SPP_ACCEPTOR_DEMO"
#define SPP_SERVER_NAME "SPP_SERVER"
#define EXCAMPLE_DEVICE_NAME "ESP_SPP_ACCEPTOR"
#define SPP_SHOW_DATA 0
#define SPP_SHOW_SPEED 1
#define SPP_SHOW_MODE SPP_SHOW_DATA    /*Choose show mode: show data or speed*/
static const esp_spp_mode_t esp_spp_mode = ESP_SPP_MODE_CB;
static struct timeval time_new, time_old;
static long data_num = 0;
static const esp_spp_sec_t sec_mask = ESP_SPP_SEC_AUTHENTICATE;
static const esp_spp_role_t role_slave = ESP_SPP_ROLE_SLAVE;
#if (SPP_SHOW_MODE == SPP_SHOW_DATA)
#define SPP_DATA_LEN 20
#else
#define SPP_DATA_LEN ESP_SPP_MAX_MTU
#endif
static uint8_t spp_data[SPP_DATA_LEN];
static int send = 0;
static void print_speed(void)
    float time_old_s = time_old.tv_sec + time_old.tv_usec / 1000000.0;
    float time_new_s = time_new.tv_sec + time_new.tv_usec / 1000000.0;
    float time_interval = time_new_s - time_old_s;
    float speed = data_num * 8 / time_interval / 1000.0;
    ESP_LOGI(SPP_TAG, "speed(%fs ~ %fs): %f kbit/s" , time_old_s, time_new_s, speed);
    data_num = 0;
    time_old.tv_sec = time_new.tv_sec;
    time_old.tv_usec = time_new.tv_usec;
static void esp_spp_cb(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
    switch (event) {
    case ESP_SPP_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_INIT_EVT");
        esp_bt_dev_set_device_name(EXCAMPLE_DEVICE_NAME);
        esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
        esp_spp_start_srv(sec_mask,role_slave, 0, SPP_SERVER_NAME);
    case ESP_SPP_DISCOVERY_COMP_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_DISCOVERY_COMP_EVT");
    case ESP_SPP_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_OPEN_EVT");
    case ESP_SPP_CLOSE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CLOSE_EVT");
    case ESP_SPP_START_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_START_EVT");
    case ESP_SPP_CL_INIT_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CL_INIT_EVT");
    case ESP_SPP_DATA_IND_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d",
                 param->data_ind.len, param->data_ind.handle);
        esp_log_buffer_hex("",param->data_ind.data,param->data_ind.len);
		for (int i = 0; i < param->data_ind.len; ++i) {
			spp_data[i] = param->data_ind.data[i];
		 esp_spp_write(param->data_ind.handle, param->data_ind.len, param->data_ind.data);
#else
        gettimeofday(&time_new, NULL);
        data_num += param->data_ind.len;
        if (time_new.tv_sec - time_old.tv_sec >= 3) {
            print_speed();
#endif
    case ESP_SPP_CONG_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT");
        ESP_LOGI(SPP_TAG, "ESP_SPP_CONG_EVT cong=%d", param->cong.cong);
#endif
        if (param->cong.cong == 0) {
            esp_spp_write(param->cong.handle, SPP_DATA_LEN, spp_data);
    case ESP_SPP_WRITE_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_WRITE_EVT len=%d cong=%d", param->write.len , param->write.cong);
        esp_log_buffer_hex("",spp_data,param->write.len);
#else
        data_num += param->write.len;
            print_speed();
#endif
        if (param->write.cong == 0) {
			ESP_LOGI(SPP_TAG, "Yeah len=%d cong=%d", param->write.len , param->write.cong);
            esp_spp_write(param->write.handle, param->write.len, spp_data);
    case ESP_SPP_SRV_OPEN_EVT:
        ESP_LOGI(SPP_TAG, "ESP_SPP_SRV_OPEN_EVT");
        gettimeofday(&time_old, NULL);
    default:
void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)
    switch (event) {
    case ESP_BT_GAP_AUTH_CMPL_EVT:{
        if (param->auth_cmpl.stat == ESP_BT_STATUS_SUCCESS) {
            ESP_LOGI(SPP_TAG, "authentication success: %s", param->auth_cmpl.device_name);
            esp_log_buffer_hex(SPP_TAG, param->auth_cmpl.bda, ESP_BD_ADDR_LEN);
            ESP_LOGE(SPP_TAG, "authentication failed, status:%d", param->auth_cmpl.stat);
    case ESP_BT_GAP_PIN_REQ_EVT:{
        ESP_LOGI(SPP_TAG, "ESP_BT_GAP_PIN_REQ_EVT min_16_digit:%d", param->pin_req.min_16_digit);
        if (param->pin_req.min_16_digit) {
            ESP_LOGI(SPP_TAG, "Input pin code: 0000 0000 0000 0000");
            esp_bt_pin_code_t pin_code = {0};
            esp_bt_gap_pin_reply(param->pin_req.bda, true, 16, pin_code);
            ESP_LOGI(SPP_TAG, "Input pin code: 1234");
            esp_bt_pin_code_t pin_code;
            pin_code[0] = '1';
            pin_code[1] = '2';
            pin_code[2] = '3';
            pin_code[3] = '4';
            esp_bt_gap_pin_reply(param->pin_req.bda, true, 4, pin_code);
    case ESP_BT_GAP_CFM_REQ_EVT:
        ESP_LOGI(SPP_TAG, "ESP_BT_GAP_CFM_REQ_EVT Please compare the numeric value: %d", param->cfm_req.num_val);
        esp_bt_gap_ssp_confirm_reply(param->cfm_req.bda, true);
    case ESP_BT_GAP_KEY_NOTIF_EVT:
        ESP_LOGI(SPP_TAG, "ESP_BT_GAP_KEY_NOTIF_EVT passkey:%d", param->key_notif.passkey);
    case ESP_BT_GAP_KEY_REQ_EVT:
        ESP_LOGI(SPP_TAG, "ESP_BT_GAP_KEY_REQ_EVT Please enter passkey!");
    default: {
        ESP_LOGI(SPP_TAG, "event: %d", event);
    return;
void app_main()
	for (int i = 0; i < SPP_DATA_LEN; ++i) {
        spp_data[i] = i;
    ESP_ERROR_CHECK( ret );
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_BLE));
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    if ((ret = esp_bt_controller_init(&bt_cfg)) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_bt_controller_enable(ESP_BT_MODE_CLASSIC_BT)) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_bluedroid_init()) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s initialize bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_bluedroid_enable()) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s enable bluedroid failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_bt_gap_register_callback(esp_bt_gap_cb)) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s gap register failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_spp_register_callback(esp_spp_cb)) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp register failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    if ((ret = esp_spp_init(esp_spp_mode)) != ESP_OK) {
        ESP_LOGE(SPP_TAG, "%s spp init failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    /* Set default parameters for Secure Simple Pairing */
    esp_bt_sp_param_t param_type = ESP_BT_SP_IOCAP_MODE;
    esp_bt_io_cap_t iocap = ESP_BT_IO_CAP_IO;
    esp_bt_gap_set_security_param(param_type, &iocap, sizeof(uint8_t));
     * Set default parameters for Legacy Pairing
     * Use variable pin, input pin code when pairing
    esp_bt_pin_type_t pin_type = ESP_BT_PIN_TYPE_VARIABLE;
    esp_bt_gap_set_pin(pin_type, 0, pin_code);
as you can see i'm trying to do echo. meanning getting data from another bluetooth device (my phone) and send it back
i'm recieving the data and when i send it back, i'm getting the data all the time until cong = 1 and then the connection is lost
how can i send only once the response, meanning, if i send from my phone "hello world" how can i make ESP32 send it back just once?
ESP_Sprite
Re: ESP32 BT write echo back once
Postby ESP_Sprite » Mon Nov 19, 2018 2:28 am
Moved to the ESP32 IDF forum.
gunar.kroeger
Postby gunar.kroeger » Mon Nov 19, 2018 1:59 pm
When you recieve a message, you get an ESP_SPP_DATA_IND_EVT event, when you finish transmiting a message, you get an ESP_SPP_WRITE_EVT.
What you are doing now is sending an echo once you recieve AND each time you finish a transmission.
removing these lines from the ESP_SPP_WRITE_EVT case should do the trick:
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
Users browsing this forum: Bing [Bot] and 121 guests
